5 stud hubs for the bluebird 310/910 struts
Quite a regular
From Taradale; NZ
I am in process of upgrading my suspension and brakes to Nissan Skyline stuff. Will use laurel fillers , avenger springs, GTS-T calipers/rotors. But having trouble finding hubs that will fit over the bluebird stub axles. I've heard and measured that ford falcon ute XA-XF will fit and also old toyota crown will also fit. Any other suggestions? cheers
Posted on: 2010/3/11 22:52
Re: 5 stud hubs for the bluebird 310/910 struts
From cranbourne, vic
z31, 280c & 300c??? as i belive they fit the jdm r31 struts..
Posted on: 2010/3/12 10:45
82 1200 ute - daily
89 R31 H.M.A.S. Skyliner - drifter
197? 1200 coupe - new drift project.
85 CMA81 nissan/ud 9.5ton banana back - tow pig for the drifter.
Quite a regular
From Taradale; NZ
i thought z31 was 4 stud, any particular year?
Posted on: 2010/3/12 22:23
No problems, only opportunities
From Geelong, Vic
later Z31s were 5 stud
you are right about the early falcon hubs though, they run the same wheel bearings
Posted on: 2010/3/13 3:01
From townsville
just get some hubs made up its the easy way got some billet ones with bearings and studs for 730 all brand new
Posted on: 2010/3/13 3:43
Quite a regular
From Taradale; NZ
Just chasing some z31 5 stud jobbies for $200, see how that goes. cheers otherwise might have to get some made.
Posted on: 2010/3/16 4:29
