will this Fusible link suit ?
From Sri Lanka
Hi Guys
Searched ever where for the 1200 main fusible link,could not not even nissan dealer has got it, found this as a similer option it has got 10 Amp Fuse inside it,will i be able to put 20 AMP fuse into this , i think datsun1200 needs max of 20 AMP stuff ,those are Head Light Bulbs
thanks
Regards
sumith
jpg  Image057.jpg (8.42 KB)
10994_4ba2fb1159771.jpg 352X288 px
jpg  Image059.jpg (9.26 KB)
10994_4ba2fb1f6bf5d.jpg 352X288 px
jpg  Image058.jpg (8.34 KB)
10994_4ba2fb37cdaae.jpg 352X288 px
Posted on: 2010/3/19 4:19
Re: will this Fusible link suit ?
should be fine mate... you could always put a 12vdc 20A circuit breaker in.. pretty sure jcar sell em...
Posted on: 2010/3/19 4:36
j car in Sri Lanka might be hard to find :P
Posted on: 2010/3/19 4:49
1200 ute unfinish'd sr20 $$$
1200 ute stocko
bumble bee drift pig
XR8 tow car / daily
bailz is orsum
That won't work. It is only a fuse, and the 1200 uses up to 30 amps, so it will probably blow.
Go to the auto wreckers, and get a real fusible link from any car there. Datsun 1200 uses the smallest fusible link. I used one from a Ford.
Do not confuse "fusible link" with "fuse".
Posted on: 2010/3/19 4:52
From Sri Lanka
Hi dd
If i Put 30 AMP Fuse inside this will that be ok ?
Thanks
regards
sumith
Posted on: 2010/3/19 5:06
No.
Doesn't your B210 have a link like this? All the B210 here and in Japan do:
Posted on: 2010/3/19 5:13
From Sri Lanka
Hi DD
Nope mine don't have it, i will be able to put any barrel type fuse into this,will that wire be enough to hold 30 AMP,it had 10 AMP fuse inside it ,i don't know whether i have misunderstood those words,what is in my mind is the small barrel inside it called fuse the cover of it with wires called fusible link ?
correct me if i am wrong
thanks
Regards
sumith
Posted on: 2010/3/19 5:20
You misunderstand. A fusible link is not a fuse.
The properties are very different. Japan-built B210s come with a fusible link to protect the un-fused portion of the wiring harness.
Posted on: 2010/3/19 5:33
From Sri Lanka
Hi DD
Ok, thanks, if i go and ask for a 30 AMP fusible link from spare parts dealer ,how do i install it to mine ?
Do you have any idea how much is it cost ?
Thanks
Regards
sumith
Posted on: 2010/3/19 5:43
You simply splice it into the main battery wire, at the battery. Ask for a "Type C fusible link".
See the photo previously posted.
They cost $8 USD from Nissan.
part number 25442-H2500 for B110.
part number 25442-H2500 for B210.
Your B210 probably already has one. They just look like a piece of wire.
Posted on: 2010/3/19 6:23
