Big breaks
From Sydney Australia
hi im new to the club and i own 2 datto 1200's and a 1000. one of my 1200's has datsun stanza front struts and disk breaks and i was just wondering if there any bigger or better front breaks that can be easily addapted ?? any help would be appriciated.
P.S. I got 15 inch TRX rims. so the bigger breaks the better
Posted on: 2003/11/10 4:45
Re: Big breaks
From Warwick, QLD
Hey where bouts are you located??
Damo
Posted on: 2003/11/10 4:52
Drive It Like You Stole It
Every Car Has 500hp In The Wet
Team NEW SKOOL
Re: Big breaks
sydney Australia
Posted on: 2003/11/10 5:00
Re: Big breaks
From Sydney, Australia
The next thing is, how much do you have to spend.
I totally recommend the vented Verada disks and Commodore calipers. I'm not sure if this works with the Stanza struts. I know it works with the early 180B (large axle) struts. I'm using these in my 1200.
If you want to go down that path, I don't believe it would cost you much more than $600-700. As I haven't bought the parts for a few years, I can't be sure that this cost is accurate.
I also know that people have looked at Stanza upgrades, and there might be a 4 spot upgrade using landcruiser parts etc..I'm not sure.
Search for stanza and brakes on the left pane.
Chris
Posted on: 2003/11/10 5:13
Re: Big breaks
From Auckland N.Z
What motor do you have in your car to justify going bigger? Im racing my 1200 and the 255mm vented stanza brakes and calipers are more than enough to out brake most of the other cars on the track. Im using m155 mintex pads and a 180B master cylinder so maybe my system is different to yours.
Posted on: 2003/11/10 5:33
Re: Big breaks
sr20de
im proably goin faster than u
i shouldnt drive so fast on the road i gues any way
Posted on: 2003/11/10 6:57
Re: Big breaks
From Melbourne, Australia
i have u12 pintara discs and hi-lux four spot calipers, there is some machining of the disc required to fit this though (opening up centre hole and redrilling bolt holes to fit)
Posted on: 2003/11/10 7:00
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: Big breaks
these just fit under 14" rims
1200 Coupe Rallycar
Re: Big breaks
From Canberra, Australia
Spelt "Brakes"
Oh yeah how do you get vented stanza brakes?
Mine aren't...
Posted on: 2003/11/10 9:19
1971 Datsun 1200 Coupe
A15 Engine. Holley G180 (32/36 Weber). extractors and 2 inch exhaust.
Standard 1200 4 speed with lightened fly wheel and HD clutch
Stanza front struts and brakes.
15x6 CSA Wheels with 195/50 rubber.
Re: Big breaks
From Auckland N.Z
Lobster I've heard some people call the 1600 stanza's (I think in S/A) but Im refering to the early 90s stanza 'EXA' theyre like a bluebird but the EXA comes in a nochback thing. I think the 10inch disks are the same on any of the normal family rwds from the 90s.
for my 1200 2 door i think I'll use the U12 set up (without the 4pots) so I get better wheel clearence and choice of offset, the EXA disks sit flush with the hub and it was bloody hard to find wheels that didnt rub on the caliper.
Posted on: 2003/11/10 11:12
