Browsing this Thread:
1 Anonymous Users
advice on dato 1000 ute |
hi guys im in the process of acquiring a datsun 1000 ute and just want your advice if theres anything major that i should look at? i've had a look and gonna take it for a drive, it's got a bit of rust which you get for an old car i guess but is there anything that should stop me from purchasing it? thanks for any help
Posted on: 2010/3/31 8:22
Re: advice on dato 1000 ute |
From Freo
all I can say is Welcome to the 1000 world... it's got the Lot!!!
steering Play, can be expensive, Shyte Brakes can be adjustment, and wheel cylc, the cyls are a bit expensive, and a little fiddly...
most everything else is pretty easy and durable...
Posted on: 2010/3/31 8:32
'68 Thou Wagon,(home now) up and running '69 2 door project, the yellow thing, A12A Project motor, for the yellow thing. A15 PSI Project Motor '72 CB750k,
haha thanks i've been wanting one for a while, it's got disc brakes on the front and is fairly tidy just a bit of rust underneath the car but nothing that can't be repaired i guess
Posted on: 2010/3/31 9:21
From Melbourne Vic
1000 utes often have floor rust issues, other 1000 models don't for some reason. in towards the tunnel and around the footwell area. 1000's are the business, welcome aboard!
Posted on: 2010/3/31 9:37
CA18DET 1200 lagwagon retired LAG510 - SR20DET 1600 sedan 1000 wagon daily - A series magic
From Adelaide, Australia
u can get rust around the tray especially where its meets the back of the cabin. front floor section as lagwagon said but inside and out. the roof (sides), below the tailgate, right underneith the dash on the sides (start of the pillarsu,will need a torch for that one), seal panels and behind the seats theres like a pressed join or somthing.
Posted on: 2010/3/31 10:19
parts needed: GX air filter box. for sale, stanza steering wheel, 1000 gloveboxes lids
oh yea got ya, will have to check it out
Posted on: 2010/3/31 11:42
Most rust spots have been covered but just in case check the rails underneath battery tray, poor windscreen seals or leaky screen leads to bad news in most interior frame and floor Apart from that if the cabin is good the rest is easy and at worst makes an easy convertible :)
Posted on: 2010/3/31 14:25
From pooraka,,adelaide
and a good convertablr. . haha =)
Posted on: 2010/3/31 20:28
620 ute -sr20det full irs vanette-a15 turb 260c- daily 1000 4dr- a15 1000 4dr- project to be sr20
garage 910
Take a medium to large size flat fridge magnet and touch it against the car body at all the places where you might find rust in a Datsun. This'll help identify any bog-spots and give you a fairly good indication of how much work you're in for.
The best thing you can do before you get involved is to gauge the scope of work of rust repair.
Posted on: 2010/3/31 22:13
why not up north :)
Posted on: 2010/3/31 23:37
