« 1 2 3 (4)
Re: Increase Combution Chamber Volume [GX head] or Copper Gasket?
My oath it's a rip off.
I need a 3mm gasket though so I'm doing it all the long way. Just did a bit of checking, I reckon stock gaskets are shyte as a reference so I scanned the head and drew my own. Finally put the Uni A3 scanner to some real use!
EDIT: The biggest inconsistency in the off the shelf gaskets were the openings for the coolant circulation....I mean the holes in the gasket were about 50% of the size of the actual vessels in the head. I wonder how many heads got hot because of this?
Posted on: 2010/4/11 8:52
From Melbourne, Oz
GX and H89 are both 29cc stock
Posted on: 2010/4/11 8:56
"I hav achieved wood"
29cc? Mine is 19........ it's as flat as a pancake, you could just about have a shave with the lip that has been left over from all the milling.
Connor,
Do you want a gasket? I'm getting mine machined up as soon as I hear back from the cheapest laser cutter- GX custom gaskets mate, good opportunity to drop your comp ratio.
Posted on: 2010/4/11 9:05
From Toowoomba, Qld
the difference in gasket to actual coolant passage size may be deliberate, to create a restriction to flow, keeping the coolant in contact with the galleries longer to aid heat transfer.
Cheers
Dave
Posted on: 2010/4/11 9:09
I've just had a look at the block and as it turns out the smaller holes are simply sized from the water galleys on the block rather than the ones on the head, so it doesn't really matter if the gasket ones are smaller or bigger. I'll keep them as wide as they are, referencing the galley sizes from the head rather than block.
Thanks for that Dave, better to be safe than sorry.
Posted on: 2010/4/11 9:19
From Melbourne, Oz
Thanks but no thanks chris, theres a long ways beffor I mount my head with lots of work to be done.
Posted on: 2010/4/11 10:10
« 1 2 3 (4)
