Arghh brakes!!!
From mandurah
today i put my 1200 coupe srtuts in my ute and cleaned up the calipers and gave the rotors a quik skim ,after mounting both new struts in the car and bleading the brakes on the hiost i put the wheels back on and found out that my wheels hit on the calipers !!!!
is there a cast 1200 caliper that i can put on to help with clearance or just grind the plate on the wheel side of the caliper ?
any help would be awsome !!
Posted on: 2010/4/17 12:23
Re: Arghh brakes!!!
From Mandurah, Western Australia
It only needs 1-3 mm clearance. So if a little of grinding with a flap disc is required go for it. As long as you dont compromise the structural integrity of the caliper itself.
Posted on: 2010/4/17 13:39
Re: Arghh brakes!!!
From mandurah
i know i shouldnt be putting a grinder near my brakes but i dont want to part with my wheels
ooww i could maybe run wheels spacers and then i wont have to grind too much of the caliper
Posted on: 2010/4/17 14:08
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
Re: Arghh brakes!!!
Nothing wrong with putting a grinder near your brakes. What is your concern?
Get struts a 1990-1994 1200 -- they are the new style that fit over 12" wheels.
Posted on: 2010/4/17 20:59
