need help im a newbie
Quite a regular
From brisbane
i got a datsun 1200 ute 1979 model 2 months ago, runs well mechenically, it was siting in a mans garage for years it is completely stock i mean completely stock, i want to bring this datto to life where do i start
Posted on: 2010/4/26 13:08
Re: need help im a newbie
From perth western australia
what sort of engine mods do you want to achieve? motor wise you can pretty much do anything you want mate. as long as you have the money to spend you can do alot of things. bodywise panels are pretty cheap if it is too rusty to be saved. this is the best place to ask ey where abouts are you situated?
Posted on: 2010/4/26 13:11
1000 coupe aka kb10
WHERE THE HELL IS ROBOCOP... DOES ANYONE KNOW
From Perth WA AUS
Drop an A15 in it, you will be happy!
Posted on: 2010/4/26 13:17
Datsun 1200 2Dr sedan.
Quite a regular
From brisbane
brisbane
Posted on: 2010/4/26 13:33
Quite a regular
From brisbane
i want to do the engine last thou because im still on my P plates
Posted on: 2010/4/26 13:34
Quite a regular
From brisbane
what should i do about the floor of my tray is it easy to repair or replace it has some small holes from rust damage
Posted on: 2010/4/26 13:38
From Perth WA AUS
Its not too hard to learn how to weld, I taught myself with a $300 Ozito gasless Mig welder.
Posted on: 2010/4/26 13:44
buy yourself some checkerplate steel and cut it to fit.. it looks awesome. just put it over the top after you have rust gaurded the original floor
Posted on: 2010/4/26 14:30
1000 coupe aka kb10
From mandurah
haha that is so dodgy joel !! ,if i was you i would just buy a cheap welder and do as much panel work as possible ,and for the floor i would just buy a big piece of 2mm plate and then cut the floor out and drop the new piece in ,but i would make it thicker than standard cos it wont get little dents in it like the standard floor and will probly stiffen the back of the ute up and i might handle a little better ,then you can still put the checkerplate for look
welcome to Datsun1200.com !!
Posted on: 2010/4/26 14:47
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From Townsville, Qld
my blue ute had the dodgey checkerplate welded over rust
Posted on: 2010/4/26 15:11
