rocker shaft bolts
From sydney.nsw
does anybody know if there was any model a series head from factory that came out with rocker shaft studs instead of bolts.need to find out, title taken off junior sedan driver for using studs, not bolts.junior driver has been suspended and fined and called a cheat that bulls**t,,, im sure that every other car there has not got factory 30 year old nuts + bolts or studs in it. "what a joke"
Posted on: 2010/4/30 12:04
Edited by bige on 2010/4/30 12:30:33
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
Re: rocker shaft bolts
From Townsville, Qld
did someone protest against him and if so can he counter protest?
Posted on: 2010/4/30 12:13
From sydney.nsw
only if a a series came out with studs from factory
Posted on: 2010/4/30 12:21
looking pretty slim unless there was any Australasian models with them as homologated parts for thier series
Posted on: 2010/4/30 12:28
EDIT: Never mind.
Posted on: 2010/4/30 14:34
they have to find something to put down an A series as it embarrasses too many modern engines. In the rules pdf nothing states bolt quality so I undertand your frustration.
Posted on: 2010/5/1 0:23
From tassie
what happened with this head is as follows
when pulling engine down for a rebuild the last 1/2 a dozen threads pulled out of the head
upon checking the depth of the threads in the block i found some studs that were the correct size and used these,In no way is this a performance enhancing modification it was done to simply reclaim a head that would possibly had to be thrown away,
You ask why i did not use heli-coils i build put my engine together my self and do not have heli-coil gear in my shed.
under the code of practice for engine reconditioning section 2.4 you may use suitable reclaim techniques
to be fined 1000 dollars and disqualified for 12 months is totally wrong as there is people out there that are using titanium rods cam followers etc and that is wrong i even had one person ask what rings i use i told him standard of the shelf cheap as chips rings his reply he has chrome molly rings made?????
Posted on: 2010/5/1 3:02
Good for you. Since it was totally wrong, your appeal will be granted.
Posted on: 2010/5/1 4:50
From Perth WA AUS
Thats just being petty, good luck with that.
Posted on: 2010/5/1 10:31
Datsun 1200 2Dr sedan.
I'd be real interested to have someone explain to me how the use of studs to secure the rocker shaft provide an improvement in either performance or reliability.
Standard bolts in threads that are in good condition are not known as a common failure point in our Datsuns, the threads are usually damaged when the bolts are removed or re-installed. The additional strength of studs over bolts is like comparing the killing of ants with a 2 pound hammer or a 4 pound one.
The end result is exactly the same.
Good fortune with any counter protest that you may mount.
Posted on: 2010/5/2 17:14
Love your Datsun.
Treat it well.
