Wolf 34d v4..... Who is running one on a CA
I would like some info in a wolf 3d on a Ca as im just about to put one in my ute. Any hints or problems i would like to know about to get this job done as easily as possible? Also do i need the maps to get it running and what parts will i need to change b4 this comp will work for me?
Anything will be a great help. Thanks Rhys
Posted on: 2010/5/2 11:15
Re: Wolf 34d v4..... Who is running one on a CA
From Perth WA AUS
I ran a Wolf 3d on a subaru easy to set up with the manual and sensors.
Posted on: 2010/5/2 11:21
Datsun 1200 2Dr sedan.
From Perth WA AUS
Wasnt there a 4d model?
Posted on: 2010/5/2 11:24
I would have to get my hands on a manual and the right sensors for it then. Not shore wich ones i will need to change tho?
Not shore if there is a 4d model.... I know there is a version4 and think a version5 now.
Posted on: 2010/5/2 11:34
For a cheap car these datos can get super expensive....!
All the bits for my ute have been acquired, I only need time and a panel beater/painter! Anyone able to help
did u speak to tommo??
Posted on: 2010/5/2 11:41
Car free
Yer i gave him a call yesterday mate. Thanks for his number and help getting me onto a good bloke like him. Knows his #OOPS# and i hope i can learn a bit off him. Hope to take my ute down there in a couple of months on a wknd and get it all in and tidy.
Posted on: 2010/5/2 11:44
Has anyone got the manual for a wolf3d v4 cause i have the unit but not the manual.
Also the senors that il need to get this computer in?
Any feed back will help me out so thanks in advance
Posted on: 2010/5/3 13:11
From Perth WA AUS
Probably a silly question, but have you checked online for a downloadable manual?
I think from memory the 3D used ford sensors (not sure about the map sensor though). Sorry probably not much help but its been about 7 years since I played with a Wolf, no pun intended!
Posted on: 2010/5/3 13:26
Thanks levey. I will get the girl onto finding out if there is a down loadable manual tomorrow. I have no idea of the sensor side of things so ill have a look into the ford sensor comment.
How come alot of people have not put these in there Ca conversion?
Posted on: 2010/5/3 13:39
From Melbourne Vic
i run one on an sr20det. You can buy the sensors from wolf, all you need is an air temp and water temp. Wolf are in bayswater and are very helpful.
You dont necessarily need a map, you plug in figures of your engine 4 cyl sequential inj size etc etc but any good tuner will do this for you if you cant.
Posted on: 2010/5/3 14:58
CA18DET 1200 lagwagon retired
LAG510 - SR20DET 1600 sedan
1000 wagon daily - A series magic
