« 1 (2) 3 4 »
Re: ca18det fitting into ute
From Nyngan, nsw Australia
if you just purchase the x-member and mounts from them, you'll need there g/box tunnel aswell, my engineer said 10mm clearence off back wall, but ive gone 25mm to allow all pipe run around the back of the motor...still plenty room up front for the cooler/radiator
Posted on: 2010/5/9 0:19
living is good,.....
From Rosewood, QLD
my SR kit fits so far... havent tried to put the booster in yet...
Posted on: 2010/5/9 0:22
1971 B110 sedan project.
2012 Nissan Micra daily.
From Griffith
im gunna try and keep the standard tunnel if i can , i no it has been done before. Just might need to be massaged a bit
Posted on: 2010/5/9 0:30
From Sydney
your gonna be in all sorts if you dont get a larger tunnel. unless its a automatica tunnel then it might be okay, but why would you bother spending all this money on this conversion when your not even gonna do it properly by cutting the tunnel? do it once do it right and dont be a tightass...
Posted on: 2010/5/9 0:56
so the maddat kits the way to go ayy ???? for the sr20 or has eny 1 had a kit made up in qld or is maddat the only decent 1
Posted on: 2010/5/9 1:01
yeah ive got the trans tunnel as well but there is no way with the gearbox mounted in the correct position that the engine is gunna clear the firewall, after satring at it for a few hours it looks like it needs to come forward about 10 mm and maybe sit down 5-10mm too. not sure if i want to cut the maddat welds and reweld thats sort of why i bought it in the first place, so it would fit without any issues
Posted on: 2010/5/9 1:10
finally gettin the ca18 ute project underway
Sunny’s were made to be drifted, it says so in the factory service manual: Service after every drift day and mountain tounge or 100,000km’s
This mite sound like a stupid question....but have you got the x-member in the right way round?
its been done before
Posted on: 2010/5/9 1:15
hahhahahhahhhahha
yes.( dont worry ive thought about that too)
Posted on: 2010/5/9 1:18
From Sydney
you have 2 options...
1. you can go to a perfromance shop that dose conversions and will make you one to fit to what you have and measure every aspect and get a good very thick xmember, but you know its done to suit everything you need..
2. buy a maddat kit and hope your chassis is not twisted and everything is on the money, worse case you gotta start spending $$ to aline everything.
you chose i did not bother with a maddat kit for my 13b rotary as my mechaic said he can make better and work around what i needed done ie: lower the engine more/raise more, supra gearbox xmember mounts, tailsharft measurements and i got a good deal for a quailfied performance shop to measure and line up everything from raidiator, engine, gearbox, tailsharft, everything in the drive train for $2500
oh and a very large gearbox tunnel welded to the floor.
now i just need very basic wiring as my car in not injected but carbureted...
so basicly is it worth the hassel and stress and bleeding knuckles when there are ppl out there who can do it for a lil bit of $$, but done 100%
Posted on: 2010/5/9 1:19
sweet thanks man for the info
Posted on: 2010/5/9 1:23
« 1 (2) 3 4 »
