Weber 32/36 linkage?
From Gawler, Sth Aust
Hey guys. I just got my weber back from the rebuilder. And I'm now real eager to give it a try. I have a redline adapter but no linkage.
What have people done to hook up there cable?
Would it just be worth paying $80 for it?
Some one told me I could use parts from a stock carby to get it workin, but they were drunk.
Posted on: 2010/5/17 12:37
72 B110 A14
71 B110 A12a (Parts)
06 380 VRX
Re: Weber 32/36 linkage?
i have modded stock carbi stuff to fit a 32/36 or u can ust the linkage from a gemini stock carbi and they work a treat ive done both easy as pie
Posted on: 2010/5/17 12:57
Car free
From mandurah
but pies are hard to make !
i had the same problem but mine had the wrong length linksin it and wouldnt open fully so i modded the standard ones as you siad
Posted on: 2010/5/17 14:01
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From Townsville, Qld
Is the redline ball connection spring return throttle cable and the carby lever and ball going to cost $80 whatta rip! I'm pretty sure I got out of that for like , um...$70
0_0
Posted on: 2010/5/17 15:43
Thanks for the help guys, a stock linkage is now attached to the weber. Just needed one extra washer so stop it from stickin open on the return spring (that would have been scary).
it isnt in the car yet but hopefully there will be enough movement on the throttle cable to get both throats open.
The linkage i was quoted on was not Redline, it was from the guy on ebay whos sells heaps of carb kits, manifolds, linkages, carbys, jets.
Posted on: 2010/5/18 8:49
72 B110 A14
06 380 VRX
Be a little careful with the ebay guys, they make a very good profit on some of the products, the obvious perk being that it all gets sent to your doorstep.
I have had a couple of items supposedly completely rebuilt with shocking insides and very old gaskets (as opposed to the refreshed- re-kitted description). My Mikuni PHH's are a good example.
Good to hear to got your own setup, but yeah fix that WOT (wide open throttle) issue!
Posted on: 2010/5/18 8:57
The linkage is clear of the return spring now so that issue is resolved.
It looks so clean its almost to clean put in grimey (currently running) 1200.
jpg  DSC00857.JPG (128.90 KB)
11893_4bf25d12c80a2.jpg 640X480 px
jpg  DSC00856.JPG (138.56 KB)
11893_4bf25d8131e54.jpg 640X480 px
Posted on: 2010/5/18 10:33
72 B110 A14
06 380 VRX
