« 1 2 3 (4) 5 »
Re: sprung load locker = phantom grip
From Melbourne, Australia
im not offended im just saying from experience they work
i suspect people that they dont work for are just pissed off cause "it doesnt leave 2 lines down the road like there CIG locker did"
these things are puss for droping bangers but for improving times they are gold
Posted on: 2003/11/19 1:25
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Millgrove Vic OZ
You are probably right that it is more your driving ability than anything the diff can do for you.
See the wheel marks coming out of tight corners power on and there is ususally only one wheel spinning from what I have seen of them?
Posted on: 2003/11/19 5:29
Cheers Feral
im already too far down the road to see the wheel marks but if i dump it into third from high revs in second the arse tries to overtake the front, kinda like any lsd car i have been in
Posted on: 2003/11/19 10:47
1200 Coupe Rallycar
From campbelltown (sydney) australia
this may sound stupid but is it called a cig locker coz u just weld the diff centre up? ie CIG
welder company.
Posted on: 2003/11/19 11:09
From sutho shire
why not save a little bit more money and upgrade 2 a hilux..? they arnt that exspensive..
and will never have a problem again..
Posted on: 2003/11/19 11:20
*1200 ute ca18det (CYA-18T)
256 rwhp at 14psi wanting more power
Team New skool
From Canberra
Kegs,
Yes thats exactly what a CIG Locker is, an open centre welded up so both wheels always do the driving. Lots of rally guys do this because it's the easiest way to get traction in the dirt. Can do some nasty things to the cars handling, usually understeer into corners and oversteer out. A change of driving style is need to get the best out of them in the forrest.
Posted on: 2003/11/19 22:19
yes most rally guys with CIG i would say actually slow themselves, as they are quite messy and usually slower through corners with mass amounts of oversteer, quite impressive but slow
oh, and, have u ever tried to fing the right hi-lux diff for the conversion, good bloody luck mate, word is the lsd units for em are wearing thin too
Posted on: 2003/11/20 0:25
1200 Coupe Rallycar
1200coupe
did you ever finish making your own phantom grip?, just wondering how you got along with it?
Posted on: 2004/5/18 11:48
1200 Coupe Rallycar
bump
Posted on: 2004/5/20 11:59
1200 Coupe Rallycar
From Canberra
Yes mate, it's finished and in the car. I havent been able to test it because I have been flat out with ARC stuff plus got ripped off by a company here in Canberra because I asked them to straighten and ballance my ultra light tailshaft and they sent it back to me worse than when they got it. I can tell you that I was not happy - every time I give part of my coupe to someone else to fix they end up F*#kin it.
I have been searching the forums high and low to find a cheap replacement out of a ute and finally I have. Only delay is that its in Sydney so hopefully a mate will pick it up for me this weekend. Tailshaft should be back in the car sometime next week and will start testing sometime after that.
The springs that I showed in the photo album of the PG I made have been upgraded to stronger springs because I found there didnt seem to be enough preload with the others.
As far as the operation of the PG goes - all the springs do is ensure that the plates are in contact with the diff gears, its the action of the diff drive pin on the inside slope of the plates that locks and unlocks the PG.
Something else of interest - there has been talk of the possibility of fitting a Subaru LSD to H165. I posted photo's of the physical differences in the photo album a few months ago. Well I have my hands on a smaller Subaru LSD, it's viscous and not multi plate but it is smaller so I will also be checking that option out when I have the time. There are not enough hours in the days at present
Posted on: 2004/5/21 0:44
« 1 2 3 (4) 5 »
