wanted datsun 1000 heater hose
From Melbourne Vic
im after the little lots of bends one that exits the rear of the head and goes to the drivers side of the heater.
where the hell can i find one?!
Posted on: 2010/4/13 14:52
CA18DET 1200 lagwagon retired
LAG510 - SR20DET 1600 sedan
1000 wagon daily - A series magic
Re: wanted datsun 1000 heater hose
From Freo
here's a tip..
undo to heater box... pull it back a bit.. (thats the trick bit) feed on some 1/2" silicone heater hose, try and use the 1000 fitting that goes on the head.. it's the one with a little kink in it..
not the 90 deg one.. works a treat.. can't use standard heater hose, it kinks..
Posted on: 2010/4/13 14:59
A15 PSI Project Motor
'72 CB750k,
From Melbourne Vic
hmmm cool i'll give that a go! as in mount the heater back a bit more?
Posted on: 2010/4/13 15:02
From Freo
no as in pull it back, fit the hose, and refit the heater..
it's near impossible to get the hose on in place..
Posted on: 2010/4/13 15:13
'72 CB750k,
Uh, I have my heater hoses running the opposite way, ie: my heater outlet goes into the back of the head and the inlet (drivers side) from the t join near the bottom of the rad at the front of the block. I am SORE after reinstalling my heater today ( lotsa weird contortions to put it back in) but it all works a treat so far. I wondered for a while which way it was to go back but this is the only way I could make it work and thought it must have been that way to begin with, Would this make much difference?
Posted on: 2010/5/20 12:46
why not just use stright heater hoses and use the metal or brass 90deg bends?
cheap to use heater hose and cheap to get the t peices.
i plan on this method if i cant find the little hoses in the 1200.
Posted on: 2010/5/20 14:21
From Freo
it would be nice, but one of the heater pipes hides up inside the dash and it's got some short sharp bends to get out the hole.. (in the 1000)
Posted on: 2010/5/20 14:58
'72 CB750k,
The 1k inlet hose is the one that's tricky, it mounts from within the cab whilst the outlet from the engine bay. To mount the inlet from the back of the head I would need another bit of hose additional to old kinky runnin 180 degrees to join up, hence why I just ran the outlet to the rear. So The question remains what is the direction of flow for the heater loop? Does it matter which way round the hoses run?
Posted on: 2010/5/20 22:11
Meh so Im pretty sure Ive got this the wrong way round, shouldn't make a difference If I leave the valve open, but hypothetically, what would be the ramifications if I shut it off?
Posted on: 2010/5/21 1:14
From Freo
not really, it's just water flow,
just make sure you operate the tap quite often, to make sure it doesn't seize up..
'72 CB750k,
