quad throttle body injection
From Sydney
does anybody on this site run it
and what are the real costs involved for a conversion
i like the idea but would it not be worth the costs compared to twin webers?
Posted on: 2010/5/26 13:16
Re: quad throttle body injection
From Adelaide, Australia
Are you talking mechanical injection hillborn etc. or electronic?
I think the cheapest way out would be custom manifold with motobike efi throttle bodies, still probably with tuning messing around etc. you'd be close price wise to a well setup pair of webers.
Posted on: 2010/5/26 13:19
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From Sydney
oh right.
i saw throttle bodies that basicly bolted to
a webber manifold
EFI i guess but the time you add fuel pumps computer and bits
it would be hell expensive.
Posted on: 2010/5/26 13:41
From Geelong, Vic
doesnt have to be that expensive, if you go the efi hardware or similar route then it does actually HAVE to be expensive
but GSXR throttle bodies on a custom manifold with a megasquirt wouldnt be that expensive, its not like webbers are that cheap after you get some, then rebuild them, get a manifold and linkages and then get them tuned to suit
Posted on: 2010/5/26 14:01
From Sydney
Yea that was what i was kind of thinking about the webbers it would be close to 1500-2000 for a full complete setup + profesional tuning
would it be better spent on efi????????????
Posted on: 2010/5/26 14:41
From Geelong, Vic
probably, and once you have efi all up and running its a nice easy step to turbo it
Posted on: 2010/5/26 14:47
From Rosewood, QLD
yeah i have been wieghing up the twin webber or EFI options for my Z24 and im thinking EFI is going to be cheaper depending on an ECU and as PIGDOG says easy step towards turbo once its EFI
Posted on: 2010/5/27 0:19
1971 B110 sedan project.
2012 Nissan Micra daily.
From Southern Highlands, NSW, Australia
I'm so glad I went efi, sure the initial setup cost may have been a few hundred dollars more than webers but I probably saved that and more by not having to buy jets/linkages and stuff and getting someone to tune it. The car starts perfectly every time and runs like a train, I haven't had to touch anything to do with the engine or injection for the last 2 years.
I was looking at throttle bodies off a motorbike for a while since I already had a manifold for motorbike carbs, but am glad I decided to go with the efi hardware throttle bodies. They make setting it all up very easy.
Posted on: 2010/5/27 2:58
'72 1200 sedan hillclimb/supersprint car
From Sydney
So could it be done for 3k????
So instead of always checking ebay for some webers il just save for a while
and go efi?????
Posted on: 2010/5/27 5:15
From Rosewood, QLD
i recon 3K should be sufficient, maybe not quad throttle bodies but im not sure... i know i could get my Z24 EFI for that cash just dont know what ECU to run.
Posted on: 2010/5/27 6:24
(1) 2 3 »
