« 1 2 (3)
Re: mig welded diff
From Geelong, Vic
GG if datsun axles break they break right after the axle spline, then the large bit of the axle continues to spin around and make a mess of the centre...if you are carrying some speed when it breaks
old holdens and stuff break near the wheel bearing as the axle is undersized the whole way
Posted on: 2010/5/27 14:10
Re: mig welded diff
From Snohomish, WA USA
A H145 will hold up most builds on an A series motor, and some CA motors. I ran a H145 on my early A15 motor that was build with a racing cam and dual webers. I was drag racing the car. I think I even ran Nitrous on the H145. It held up. I wanted mor traction so I moved up to a H150 but welded the spider gears. At that point I also added a supercharger to the system. With both wheels spinning on the H150 it didn't take long to put to much torque on the axles and I ended up breaking one of them. I was told with my set up that I would not break a H165 so I went to that and welded up the spider gears. Half way through the race season, I broke that one to. Welding the gears puts to much stress on the axles. You won't break the weld as long as you do a good job of welding it. But you may break an axle shaft.
Now Im up to a H190 out of a 320 pickup. These axles are huge. I hope it holds up to the new Z24 motor that is going in.
Project is close to being done.
Posted on: 2010/5/29 1:24
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
Re: mig welded diff
cracka50 wrote:
Hi bit of a noob question but does welding the centre of the diff weaken or strengthen it?
or will it just weaken something else
was thinking in the back of a lightweight ute behind a 1400 it would be ok??
oh and i know they are illegal
Ever wonder why they are illegal?
Do you know that your insurance company will wipe you like a dirty arse if you prang it & discover that it has a locker?
[You agreed to keep the vehicle in a 'roadworthy' condition & the locker doesn't qualify.]
Posted on: 2010/5/30 0:59
Love your Datsun.
Treat it well.
Re: mig welded diff
From Sydney
Whats your point??????
Anything sick is illegal, thanks for the advise.
Posted on: 2010/5/30 2:00
Re: mig welded diff
From Geelong, Vic
can just get a really tight LSD that never slips with the weight of a datsun, then it would be legal even though it would act exactly the same as a locker. as techincally the axles arent jointed...just takes alot to unjoint them
Posted on: 2010/5/30 2:10
Re: mig welded diff
From Sydney , NSW
Pigdog has hit the nail on the head! I use one of Topgear's Torsen LSD in the racecar and they are worth their weight in gold!!! LSD is really the only way (yes they cost $$$, but well worth the investment) whilst lockers will try to kill you on a wet public road! The car will only turn quickly with throttle input in the wet - a real drama even if we are as good as we think we are
Even the LSD in my XR6 tubo ute commands a lot of respect in the wet ...... any real boost and she will kick sideways instantly!!!! At least with an LSD your car will turn corners when you get off the gas - and save those sweet rims from snapping in half on the gutter !!!
Cheers.
Posted on: 2010/5/30 3:48
All torque, no traction
A division of "My mate's ....." engineering
Re: mig welded diff
From ACT Aus
haha so true!
seriously, in the wet i've only found my car to be more predictable with a locker, open diff would single spin then light up both unpredictably and jump out sideways and start tank slapping. i learnt how to control it on the racetrack and lockers are very predictable if you have some experience.
plus it does hektik doughies now!
Posted on: 2010/5/30 4:38
Re: mig welded diff
From Sydney
Bah ha ha ha heckdik doughies thats classic !!!!
I ve found the same thing one wheel gets spinning which is ok than the other kicks in or they swap sides, pain in the ass and very unpredictable.
Locker/LSD predictable and awesome with the right throttle control.
Wouldnt a LSD be like 1500-2000?
Posted on: 2010/5/30 10:44
Re: mig welded diff
From ACT Aus
haha yeah they go off!
yeah lsd's are expensive for a good one, and even #OOPS# ones are in the hundreds. my locker on the other hand, free short of the welding wire i guess :D
Posted on: 2010/5/30 12:02
unfamilia wrote:
You have bump stops? Your soft
« 1 2 (3)
