« 1 ... 3 4 5 (6) 7 8 »
Re: PERTH BOYS CRUISE
From mandurah
yes but i cant be fuked pullin it all apart and plus i want an exedy extreme so i can reuse it for my good A15 that i want to biuld and then i want DBA slotted and cross drilled front rotora for the 120y struts and then rebuild kits and pads so it should cost me roughly 300 and something and then i need rust repair stuf and welding wire so it might be readu in time ,and my ute got hot today and i was goin down the freeway at abpout 100kms and ut was right up there on the gauge !! so i need to fix it up first and then i might go to the cruise and why kis there ceuises if nonoe takes there 1200s and there is heaps of 1000s there ?
Posted on: 2010/5/30 12:33
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From Perth WA AUS
A vid from last years Toodjay meet:
http://www.youtube.com/v/cDjcJHi4uWs
Posted on: 2010/5/30 15:28
Datsun 1200 2Dr sedan.
From Albany, Perth Australia
that wasnt the last meet but was the last targa we all went too...be warned of john the magna man....hahaha havent heard from him in a while, did we scare him off?
Posted on: 2010/5/30 15:55
1200 Smerf Mobile
From mandurah
haha it almost hit your motor nigel ,and the magna didnt have much damage compared to the thou
Posted on: 2010/5/30 15:57
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
well if the thou had its bumper on,like its meant to it wouldnt be so bad....the rad was stuffed with the fan going into it
Posted on: 2010/5/30 16:05
1200 Smerf Mobile
From Perth
Exedy don't make Xtreme clutches
Thats Adelaide Clutch (clutchpro etc)
And a stock Exedy clutch is 15% stronger/heavier than a stock clutch
They are fine...I beat them up behind A15's all the time
And forget Xdrilled rotors... they are wank factor
Spend the money on slotted rotors and parts that actually help your car perform
Posted on: 2010/5/31 1:00
wat a #OOPS# way to start the day seeing my datto get smash;d
Posted on: 2010/5/31 2:24
1200 ute unfinish'd sr20 $$$
1200 ute stocko
bumble bee drift pig
XR8 tow car / daily
bailz is orsum
From Perth WA AUS
Says the man who chopped up the rad support with an axe! ;)
Posted on: 2010/5/31 10:24
From Freo
AXE Murderer... !!!
Posted on: 2010/5/31 10:33
A15 PSI Project Motor
'72 CB750k,
From mandurah
ok i got a price on a new proclutch and it will cost me $107 and then i just need to put it in and the rotors im looking at are slotted only and are $101 each ,then pads are $54 and rebuild kits are $11 for both sides but this is for the 120y struts with pbr calipers ,and ill let a certain some one know before i buy anything, just incase this certain some one wants them :)
Posted on: 2010/5/31 13:00
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
