(1) 2 3 »
Installing Thermostat
From Sri Lanka
Hi Guys
I have removed my Thermostat and running the car without it as my dash gauges were problematic,Now i have made the dash gauges, and thought of installing a new thermostat as my car is running very cold as below pic, can i do it my self any advices on this, i don't see any screw or anything to tight it up in the outlet,i got 2 bolt screw type outlet as per the picture here
Thanks
Regards
sumith
jpg  Housing.JPG (14.49 KB)
10994_4c0394a72a6e4.jpg 512X384 px
jpg  heat.JPG (9.85 KB)
10994_4c0394c8a4d0a.jpg 352X288 px
Posted on: 2010/5/31 11:52
Re: Installing Thermostat
pretty easy to do. you need a workshop manual.
you undo the 2 bolts, drain the coolant, clean the old seal off the housing and the head part- dont let any fall in the head.
install the thermostat correct way round and place paper gasket or use gasket sealer.
let the sealant cure slightly, bolt it up then wait 12 to 24 hours for sealnt to fully cure. fill up with coolant and test.
try here
Posted on: 2010/5/31 13:01
From Bendigo, Victoria
Not too much tension on the bolts, they break easy.
Posted on: 2010/5/31 13:16
From Sri Lanka
Hi Guys
Then thermostat is just tighten between engine housing without any screw is it ? then put the gasket, then housing and tighten ?
Thanks
Regards
sumith
Posted on: 2010/6/3 6:57
From ACT
That is correct Sumith,
The thermostat will fit nicely in a small recess machined into the head. It just balances until you put the housing back on.
As unfamilia said it very easy, paying particular attention to the orientation of the thermostat (look at the old one as you take it out)
I have used sealer and gasket and there doesn't seem to be much difference really, except sealant is easier to find and reapply if u do stuff somethin up.
Ivan's advice is very good, remember the bolts are steel and the head is aluminium. In fact sealant is quite good because it is flexible the packae usually reccomends only doing the bolts up finger tight while the sealant cures and then applying maybe 1/2 a turn with a spanner to make it seal watertight
Good Luck mate
Posted on: 2010/6/3 9:30
Now riding dirtbikes:
Lots of A series Datto stuff for sale
he doesnt have a thermostat in there at the moment, only go in one way really, with the spring facing to wards the front of the car from memory.
Posted on: 2010/6/3 10:46
From ACT
right you are, oops ;) I hope you can remember how it looked Sumith.
But Unfamilia is right about the spring.
Posted on: 2010/6/4 9:38
and look for the small air hole has to be on the top mate its not hard at all if u need help let me no
Posted on: 2010/6/6 7:21
From Sri Lanka
Hi Guys
Turning all around to find a thermostat , no where i can find ,any one no any other compatible thermostat from any other car model that will suit for b210,checked with nissan dealer they said they will not bring these items down, some people says b210 doesn't have themostat
(they don't know it because everyone is running without thermostat)
unfortunately i don't have my old part also
did not think that this would be a disaster to find a thermostat
Thanks
Regards
sumith
Posted on: 2010/6/10 7:08
All car engines should run a thermostat, and without doubt all Nissans were originally fitted with one.
compatibility is tremendous. Certain Honda, Isuzu, Nissan fit the Datsun A-series engine exactly the same
Also more if you change temperature rating. You can use a wide range of temp from 160F to 195F thermostats.
Posted on: 2010/6/10 7:42
(1) 2 3 »
