« 1 ... 6 7 8 (9) 10 11 12 ... 22 »
Re: datski's 1200 sedan V1.2
From Albany, Perth Australia
everything standard...as i would have to make new extractors to suit the solexes
Posted on: 2010/6/13 11:54
1200 Smerf Mobile
From Perth WA AUS
I have extractors to suit solex manifold
Posted on: 2010/6/13 13:08
Datsun 1200 2Dr sedan.
yeah but you are using them arent you nigel...i still need to paint mine but i got no money to buy paint at the moment
Posted on: 2010/6/13 13:13
1200 Smerf Mobile
From Perth WA AUS
I am going to put the GX manifold on.
Posted on: 2010/6/13 13:19
need 2 paint mine and get some heat wrap. Spent the last of my money buying all the stuff i needed 2 bolt the head down. Do i actually need studs for the intake and exhaust or do you think that just bolts and lock tight will be good enough
Posted on: 2010/6/13 15:00
1200 Smerf Mobile
From mandurah
uumm i would go for studs and i think there is a set on my A12 that are wiating for you if they will fit ,just bring a bolt that will fit and you can take the studs out of one of my A12s
Posted on: 2010/6/13 15:07
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
from memory i was told that you could use just bolts as long as they aren't too long. I have some perfect bolts as well
Posted on: 2010/6/13 15:11
1200 Smerf Mobile
From mandurah
but how would you put them in with the manifolds in the way and it would be kinda hard to put them in, but if it works do it
Posted on: 2010/6/13 15:13
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
its not hard 2 bolt them on as its just as hard as if the studs where there
Posted on: 2010/6/13 15:15
1200 Smerf Mobile
From mandurah
ok ,have you got valve springs and push rods ? is there anything else that you might need ,from memory ?
Posted on: 2010/6/13 15:21
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
