Radiater Cap on Engine Heat ?
From Sri Lanka
Hi Guys
Just wanted to share your knowledge on radiator cap PSI rate and compared to it the engine temperature ? as i remember my Radiator cap is not the stock probably from heavy vehicle or equipment i guess, will that may have any effect on my car Heating ? Like Increased PSI to Increase engine temp or decrease engine temp ?
Thanks
Regards
Sumith
Posted on: 2010/6/14 12:33
Re: Radiater Cap on Engine Heat ?
It has no practical purpose. I don't know of any automotive radiator caps with "too high" pressure for Datsun.
The most common caps are 14 psi. With 180F/82C thermostat, you can use them or a lower pressure cap.
Posted on: 2010/6/14 17:31
From Sri Lanka
Hi Guys
My Radiator cap is from MMC 4DR5 Jeep or Willis jeep, i don't know what exactly PSI amount on it
thanks
Regards
sumith
Posted on: 2010/6/15 4:57
It is no problem.
Posted on: 2010/6/15 7:23
From Ringwood, Melbourne, AUS
The only restriction to radiator cap pressure is what pressure your system will hold. Too much pressure you will spring a leak!
The point of a radiator cap to raise pressure is to raise the boiling point of the coolant. As the prssure rises so does the boiling point, in this way you get a few extra degrees of temp before boiling the coolant.
From wikipedia:
The boiling point of water is 100 °C (212 °F) at standard pressure. On top of Mount Everest, at 8,848 m elevation, the pressure is about 260 mbar (26.39 kPa) and the boiling point of water is 69 °C. (156.2 °F). The boiling point decreases 1°C every 285 m of elevation.
So you can see low pressure equals low boiling point.
Posted on: 2010/6/15 7:49
Deano
