choke chugging
Quite a regular
From Perth
hey all, This is more of a curiosity rather than a problem.
When my little A12 is cold and i have the choke on, it chugs and misfires (no backfirirng) while its idling. But once it has warmed up and the choke is off it runs as smooth as silk......any suggestions to why?? Carby has just had full rebuild.
thanx
Posted on: 2003/11/28 2:37
1980 sunny std dreaming of ca18det
2000 CBR600F4
Re: choke chugging
From Collingwood. Victoria. Aus.
Does it sound like you are choking it??
use less choke
Posted on: 2003/11/28 3:05
Never ever grow up
Re: choke chugging
Quite a regular
From Perth
i adjust the choke as required, this helps only a little, but it still chugs a bit!
Posted on: 2003/11/28 3:16
2000 CBR600F4
Re: choke chugging
Quite a regular
From Flinder View Qld
Mine is the same... She can be a real pig when she is cold... but adjust your choke cable and it should (the chugging) come good. As for the miss fire i havent been able to fix that problem either.
Posted on: 2003/11/28 3:27
Re: choke chugging
From Perth W.A
mine does that a bit now when it's cold i think it's just because it's cold
Posted on: 2003/11/28 3:30
120y Coupe
120Y coupe Race car (SOON)
120Y Sedan for the Lady
Re: choke chugging
From Sydney, Australia
Datsun 1200 choke mechanism is a combination of restricting air (same fuel) and increased revs. The restricting air makes the carby work richer.
If your car excessively chugs, then you need to tighten up/bend the connections that speed up the idle. You need more revs at idle and less choke. So have a look at how pulling the choke cable also speeds up the idle, and you should be able to figure out how to change that to resolve the problem.
This fixed up my stock 1200 carby just nicely.
Cheers,
Chris.
Posted on: 2003/11/28 3:52
Re: choke chugging
Quite a regular
From Perth
interesting, slightly higher revs to co-incide with the richer fuel intake....makes sense, I shall give it a go tomorrow,
thanx dude!
Posted on: 2003/11/28 3:56
2000 CBR600F4
