« 1 (2)
Re: Nissan part number for FS5W60L reverse switch
are there any other reverse sensors that can be used in a 1200? maybe one thats not so long? (the external bit that is externally.)
Posted on: 2010/6/21 11:42
From Fremantle, West Australia
I think the "top gear" switch fitted to some 60 4 speeds is the same as the FS5W60L reverse switch-- that is its plunger is longer than the FS5W60A reverse switch
I tried to hunt down a shorter switch that didnt hit the tunnel but failed
One possibility is to drill/tap a small switch into the back of the extension housing ie switch facing backwards instead of sticking out the side
Posted on: 2010/6/21 12:50
From Sydney
Cable_Tie wrote:
Normally Open, or Normally Closed when removed?
I got a bucket somewhere I could dig thru. . .
Thanks for the offer... the switch would be normally open cct when removed. cct is energised when the switch tip is depressed.
cheers
benny
Posted on: 2010/6/22 0:51
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
From Sydney
ddgonzal wrote:
The 60L and 60A pn is listed in the 56-series article, don't ask me why.
Search and you shall find.
I must be blind freddy as I dont see it. The only reference I see with FS5W60L is in relation to "dog leg" shift
Posted on: 2010/6/22 1:04
1970 KB10 Coupe
S13 caliper b...
http://datsun1200.com/modules/mediawi ... ssion#Reverse_Lamp_Switch
Find on the page: Reverse Lamp Switch
the article is messed up. I'll try to fix it.
Posted on: 2010/6/22 1:22
OK, it is fixed now.
Posted on: 2010/6/22 2:21
Which type do you need?
One is Datsun 1200 and some B310 5-speed
The other is some B310 5-speed
32005-K121A Rev Lamp B110 $33.70 USD
32005-K102A Switch Rev Lamp $36.47
http://datsun1200.com/modules/mediawi ... title=Reverse_Lamp_Switch
Posted on: 2010/6/22 3:52
From sydney
I have this if it helps , it's from a cd I was given nissan put all the microfiche to cd , it contains exploded views of everything, old and new part num ect..
png  Capture 1.PNG (183.33 KB)
13163_4c25704a66737.png 1024X736 px
png  Capture 2.PNG (169.29 KB)
13163_4c257062d8a10.png 1024X736 px
Posted on: 2010/6/26 4:13
forward switch is spade connectors with yellow wires
rearward switch is bullet connectors with black wires
Both have a 7mm long nubbin
And are 13.5mm outside diameter of the threads
jpg  60L_5speed.jpg (99.35 KB)
174_4d5865c805943.jpg 800X829 px
Posted on: 2011/2/13 23:14
« 1 (2)
