Browsing this Thread:
1 Anonymous Users
1200 won't start |
I need help trying to figure out what's wrong with my 1200...it won't start. It has an A15 with 60 amp alternator and built in regulator from a 210. Less than a week ago I was having charging problems from a bad alternator so I got a new alternator, battery, starter (rebuilt). After fixing the charging problem, I drove 2hrs to college and now it won't start. All the fuses are good, all the wires are connected, the battery is fully charged, and it will run fine if it is push started. When the ignition is turned on, the warning lights (p. brake) come on as usual and when the key is turned the warning lights dim meaning the starter is taking power, but nothing happens, the starter doesn't engage, it doesn't even click. I'm thinking the starter may be the problem as we all know good 1200 starters are few and far between, but I want to know what others think the problem could be...any suggestions? -Andy
Posted on: 2000/1/11 2:25
Re: 1200 won't start |
From Snohomish, WA USA
unhook the power cable to the starter and jump it directly. If it does not turn over, it's a bad starter.
Posted on: 2000/1/11 2:34
Check that the push on connector is on the back of the starter as well as the main power, otherwise otherwise it will not turn over no matter what even though the starter is drawing power. I had this problem with a short in this lead and the car would only start intermittently.
Posted on: 2000/1/11 6:51
Not too shy to talk
Maybe their is a bad wire or connection at the switch. Try using a wire connected to the pos.(+) battery touch derictly to the starter silinoid to test it. If it jump well you'll know it is not the starter... good luck and be careful with the pos.(+) wire if you leave it in contact too long it will get HOT..... It will burn..... Laters... Sergio
Posted on: 2000/1/11 8:20
Not too shy to talk
If the start motor doesn't give that nice healthy clunk noise, then its probably the solenoid. Since most Japanese cars share common parts suppliers, you can interchange solenoids from a vast number of cars. Go to your local wreckers and ask them for a broken JAPANESE starter motor with a working solenoid. These are nearly workthless to them, so it should be cheap. My local wrecker had a huge pile of them and I just kept looking through them until I found one that fitted. Start motors from any Datsun/Nissan A series engine (1000, 1200, 120Y, A10-A15) will bolt straight in if you want to just replace the whole thing. I have an A14 block with an A15 crank, A15 flywheel and A12 starter motor working just fine. If you are a bit more industrious, then you can get almost any Japanese starter motor and swap your old gear (and its housing) onto the new motor/solenoid. Shared parts suppliers - Japanese economics wins again. - Wayne S.
Posted on: 2000/1/11 8:22
From Whetstone,Arizona
Hey Andy, Well here is my two cents worth! The small spade connector wire going to the starter comes from a starter relay and that is energized by the key switch .The circuit when complete makes the solinoid shove the drive gear into mesh with the flywheel teeth and closes another contact in the starter that sends 12 volts directly from the battery via the large cable from the bat. to the starter post. Using a 12 guage wire about 2 foot or so long you can jump directly from the pos. post on the battery to the spade pin on the starter as another member suggested . if the starter is good it will turn the motor over. if it just clicks it's the starter contacts or bad starter windings . Either one means get another starter. Also check to be sure the battery posts and cables are clean and in good shape as it can be loosing voltage to turn the starter but you will usually get the solanoid to click. If the starter is good, get out your pocket voltage tester and trace the starter circuit because there is a short or bad part or wire somewhere. Haynes manuals have diagrams in the back to follow this circuit. Good Luck Steve
Posted on: 2000/1/12 8:27
From Castro Valley,CA USA
Dude, my starter did the same thing. I would take off the solenoid and clean it and that would last for a couple of days. I would use a quarter to touch the 'battery' terminal with the 'start' terminal and the car would start everytime. I replaced the starter and the samething happened. I checked the ignition switch, cleaned the battery, installed a new battery cable to the stater and nothing seemed to work. I figure, after 27 years, the wires are getting old. Anyways, I used a 30AMP automotive style relay to activate the starter solenoid and have not had a problem since ( since Aug 99). The ignition switch only turns on the 30amp relay, which doesn't require alot of current. I'll probably use a FORD style starter solenoid in place of the 30amp relay in the future. This is commonly done to solve 'hot' start problems in older GM's. If you'd like i could draw up a wiring diagram to show how this works. Angelo
Posted on: 2000/1/17 7:06
Oh yeah, I took the advice of fellow club members and hotwired the starter with a separate 10 guage wire....nothing. So I took the starter out and since it's a lifetime guarantee starter from Schucks Auto, they had to give a new one. I threw it in and it started right up...thanks for all your help Datsun Club. -Andy
Posted on: 2000/1/18 1:09
