tach help
as my build thread had:
"the tacho is a pos according to piggy. it flickers around under load but settles when cruising at revs.
i like these guages and hope its either faulty guage but reading up on them, stepper guages either need a diode soldered in line to reduce the interferance in these old cars and get a clean signal or its a bad read off the coil.
it can also mean coil on the way out but piggy has a theory that the crappy wiring on the guages getting interference form the lpg stuff.
hope its an easy fix as the guages do look good and get ok reviews against a lot of other similar guages."
any one have any suggestions. i have 1k, 2k, 10k and 50k variable restistors to try but not sure what voltage or resistace should be from a bluebird elec dizzy signal to the coil and the the tacho trigger wire from the coil to the tacho?
i thought adding 2k near coil and 1k near tacho but i have a feeling they will heat up quick as there will be more load in the signal strength. but 10 or 50k might be too much resistance.
Posted on: 2010/6/24 14:00
Re: tach help
From Adelaide
I'd punt on the input (to the tach) being high impedance and hence tiny currents so don't worry about burning resistors, in any case they're a cheap fuse. My guess would be noise, if you can't look at the signal on an oscilliscope maybe try a low pass filter with a frequency set slightly above 2*(MaxRPM*2)/60, wiki low pass shows you all the background (http://en.wikipedia.org/wiki/Low-pass ... ectronic_low-pass_filters). The low pass would cut the high frequency coil oscillations out.
I'm sure someone's solved this before.
Posted on: 2010/6/24 23:51
Edited by lamb_daiquiri on 2010/6/25 0:12:47
Re: tach help
Which tachometer do you have? The stock 1200 ones work fine with Datsun/Nissan electronic distributor. I'm using mine with a 1990s Nissan A12 JDM distributor, which is the same type as found in late-1980s Nissan pulsar E-series in USA. The type without external electronic module.
Only if you are using a 1990s DIS type would I expect you'd possibly need a resistor.
Posted on: 2010/6/25 1:05
Re: tach help
DIS type??
Posted on: 2010/6/25 2:24
Re: tach help
DIS is the newer high-energy types that became popular in the 1990s. Most tachs won't work with them, and even timing lights need to be a newer type.
Posted on: 2010/6/25 2:34
Re: tach help
From Geelong, Vic
dd, its coz hes got a stepper motor tacho so its alot more sensitive to noise apparently
just see how the resisters go mik, just keep putting in resistance till the tacho is smooth
Posted on: 2010/6/25 13:25
