A14 & T25G?
From Central QLD Coast
Heya,
Got my hands on a T25G the other day and considering fitting it to an a14. I haven't played with turbos before, so can someone help me understand a lil better.
Are they a good match? & Can the T25's be used in a Draw-through setup or are they only good for Blow-through?
Thanks in advance guys.
Clayton
Posted on: 2010/6/28 4:16
Re: A14 & T25G?
From Christchurch NZ
All garret turbos are carbon sealed, and theefore okay for drawthrough.
I'd say a t25G is a little bit too big for an A14 though.
Posted on: 2010/6/28 6:00
Forced Induction!
Re: A14 & T25G?
From SA
gday mate,
yeah im going A14 T25 not T25g but apprently the g is only like a bees willy bigger so shuldnt matter.
if your interesed ill be making up some manifolds very soon (alerady made one) for the a series; they clear standard mounts, clear the standard inlet manifold, have a t25 flange and leave heaps of room in the bay. just shoot me a PM if your keen bud
cheers
Dan
Posted on: 2010/6/28 8:45
full resto: 1971 ute check it out in projects
full resto: SR20 1973 coupe check it out in projects
Go Hard Or Go Home
Re: A14 & T25G?
From Geelong, Vic
also wouldnt think that a t25g would be too big, on my CA it was on boost pretty much all the time. so on an A14 you would have a bit of lag but it wouldnt be that bad i'd think. would just allow you to cruise around off boost if you wanted
Posted on: 2010/6/28 11:15
Re: A14 & T25G?
Thanks heaps for the info guys, appreciate it.
Thanks for the offer too Dan, I will let ya know. Guess I need to start collecting a few bits and pieces. I'm excited.
Posted on: 2010/6/29 6:07
