ribbed Pulleys size calculation for supercharging please help!!
Anyone know if the A series cam with ribbed crank, waterpump
and alternator pulleys in South Africa????
Also anyone know who can modify or make some in Victoria?
Im thinking of using 6 rib belts for the crank, waterpump
and alternator while at the back of the alternator to drive
the supercharger stay with 4 ribs like on the stock rib that
comes standard on the supercharger.
At the moment Im trying to work out the diameter of the V pulleys
they come stock with as its quite hard to work out exactly what
the diameter is with a V groove. Any ideas on correct method?
Im using the bottom of the V and got 120mm with the alternator
at 50mm meaning 120/50 = 2.4:1 for the alternator then the
supercharger pulley is 80mm so what would I need if I need the
ratio of the supercharger to spin at 2:1 instead of 2.4:1 ?
Im lost in the calculations specially when adding 500cc to the
mix and the A10 with 75mm bores or 1043cc
Posted on: 2010/7/5 1:34
Re: ribbed Pulleys size calculation for supercharging please help!!
From Ringwood, Melbourne, AUS
As long as you are consistent with where you measure I don't think it will matter.
As for the maths.. hmm, can't help off the top of my head sorry, I would probably have to work it out in a spreadsheet or something. Technology has made me stupid!
Posted on: 2010/7/5 1:51
Deano
I think Ive worked it out? Alternator spinning at 2.4 of the crank
SC pulley is 80mm and alternator is 50mm SC should be spinning at
twice its capacity for 9.5-10psi so need 2:1 ratio.
Back of alternator pulley needs to be about 67mm in diameter
to make the 80mm pulley spin at 2:1.
Now to find a way to get a custom made waterpump and crank pulley
for 6 or 7 ribbed belts. I would prefer stepped belts like on belt
driven overhead cam engines but too expensive to make the pulleys
and could be noisy.
Posted on: 2010/7/5 4:22
DD would you know if the ribbed crank and waterpump pulleys where available?
Posted on: 2010/7/5 6:28
