What does pale brown sludge under the oil cap mean?
What does pale brown sludge under the oil cap usually mean? I have a lot. Car seems fine otherwise. Isn't this a sign of a blown head gasket?
Posted on: 2010/7/6 10:42
Re: What does pale brown sludge under the oil cap mean?
From Invercargill, New Zealand
It can be condensation accumulating on the inside of the rocker cover. Check your radaitor for a water level drop or oil contamination as this would indicate head gasket or cracked head. If it is a head gasket then they are simple as to do.
Posted on: 2010/7/6 10:48
Water level was down a bit. No evidence of oil contamination oil water. The car leaks a lot of oil from somewhere - possibly from the head?
Posted on: 2010/7/6 10:54
From Sri Lanka
Hi SunnyDaze
Yes check the Radiator for loss of coolant and color of it, or else have you done your oil change regularly on it .Dirty oil also make brown color sludge if you don't change it on time
thanks
Regards
sumith
Posted on: 2010/7/6 10:56
From Toowoomba
Could be a head gasket..
Easiest way to check is to drop the oil from the engine....
If there is an 'cream' colouring then its a fair bet the gaskets cooked..
Easy to replace thou... Just make sure to check for corrosion within the galleries before refitting...
Posted on: 2010/7/6 10:57
From sydney.nsw
got somebody to do tee-kay head check.done throw the radiator,check for CO in cooling system.cheers
Posted on: 2010/7/6 11:03
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
Can also be a poorly functioning crankcase ventilation system. Check if the PCV valve or hoses are restricted or blocked.
Can also be from an engine that does a LOT of cold running - short trips etc and possibly a water thermostat that is stuck open or missing.
Posted on: 2010/7/6 13:37
It does do a lot of short trips - so maybe that has something to do with it.
Posted on: 2010/7/7 1:18
