How to Remove this Cover
From Sri Lanka
Hi Guys
Planning to make my horn this week end i guess my relay is not working , in case if my Horn Button contact is bad how can i remove this cover from the steering wheel and check it
thanks
Regards
sumith
jpg  Horn.jpg (79.75 KB)
10994_4c355ea9a8725.jpg 800X600 px
Posted on: 2010/7/8 6:14
Re: How to Remove this Cover
It is very easy to break that button when trying to remove it.
Posted on: 2010/7/8 6:23
From Sri Lanka
Hi DD
so do you mean better not to remove it ? if the button doesn't have proper contact how can i make it right ? is this cover get thread or bolted ?
thanks
Regards
sumith
Posted on: 2010/7/8 6:28
I don't remember how it comes apart.
There is No need to remove the horn button until you test the wiring. Go under the bonnet and test the relay. Measure the ohms of the wire to the steering wheel, and make sure it is earthed when you press the wheel.
Posted on: 2010/7/8 6:37
I damaged mine trying to get the center hub/horn ring off. I assumed that you could pull or pry it off like on the later Nissan cars. Wrong. You actually have to use an open end 10mm wrench and unscrew three screws from the backside of the wheel hub. It takes patience to do and is kind of a pain in the arse.
Posted on: 2010/7/8 6:41
From Los Angeles,CA. USA
1)Push down on the center hub/ horn button
2) As it's being depressed turn left...this will unlock the three plastic retainers that hold the horn button.
Posted on: 2010/7/8 7:11
hey Leo you have a Sunchaser now? (in your icon)
Posted on: 2010/7/8 7:16
Just last month I gave it to my coworkers daughter...She needed a car for college and she loved the car! Plus the bonus is when she tires of the car it comes back to me regardless of the condition!
Posted on: 2010/7/8 7:21
