Thanks for the compliments guys. Mik camera is a $100 pentax optio, probably less nowadays.
The shim is still going well. At first I hadn't re-wired the dizzy, when I cranked it I just assumed it was losing compression so I was very impressed when it all fired up.
Removing the head gasket next and running the head shim and head bare to see if this works out, this'll bump the CR as well. I guess you could use two gaskets but I'm not sure how long they'll last. Keep in mind I'm testing something I'm about to sell so I'm not really interested in alternatives.
Dan those arms are all good, just a tiny bit of play, about 0.5mm so I'm looking at buying new parts from Nissan. I really like how they fit though, very tight and secure. You be careful working on those Alfa's Dan they'll wear you out!
Took it for another drive today and had a little issue with the cooling system, seems my thermostat has decided to give up all of a sudden, quick retreat after that incident.
Really hoping a dyno session will iron out the little flutters and bogging with the carbs as the engine is a bit of work to drive when down low.
