Browsing this Thread:
1 Anonymous Users
Re: Electronic distrubuter |
Registered Users Contentmaster Usermaster
That link is to an E-series distributor, not an A-series distributor. Most E-series used the same guts as some Vanette distributors.
There is wiring information in the Vanette Distributor article
Posted on: 2010/7/13 9:05
From Pretoria SA
thanks ill be looking into that also. I like to get as mutch info about something to make an informed dicision. Please if you have some other ideas if wouldent be bad to pas them along aswel.
By the way does anyone know what the prinsipal is that a nocksensor work, a bud segested that asto a dizzy.
Posted on: 2010/7/13 9:22
From Vanderbijlpark, South Africa
that is the info for converting an e series distributor to a a series engine, you will see there that you use parts from the a series dist to convert it to the electronic e series, i've built one and works like a charm. i used a golf 1 bosh coil, the red one works very well. you must use a electronic coil e.g. the vw's. remember when using that coil, that you must remove the resistor on the current points coil
Posted on: 2010/7/13 9:40
93' Nissan 1400 a15 60a (daily) 82' Datsun 1400 ute (sold) 73' Datsun 1200gx Coupe (sold)
From Pretoria SA
mine fits, i recon it must have been converted already. Why the vw coil isnt a normal electronic coil the same?
Also can you convert the std dizzy with a vw dizzy's internals, Got a vw's dizzy and thought of converting my std a14 dizzy, Is it posable? How?
Posted on: 2010/7/13 10:12
i've seen that they use the vw internals on most mr turbo efi systems, so it will work. the golf coil gives a very good spark. to give you an ide, i was able to rev my gx with a14 setup up to 9200 rpm's with no problem, so i don't see the need into converting into the golf setup, as the e series works like a charm and takes about an hour to build and setup.
Posted on: 2010/7/13 10:17
From Pretoria SA
your right, im thinking i have some extra dizzy's , if i can convert them i will defenatly have a market, anyhow the vw's dizzy is cheap. i know a few oks with ute's(my brother), coupe's(a buddy) and 4 doors(son inlaw) that might be interisted. Mr. turbo is far so not easy to get to in the week.
Posted on: 2010/7/13 10:32
Electronic component distributor of integrated circuits, semiconductors, and other lesser electronic components specializing in obsolete and hard to find parts.Electronic Distributor stands as preferred source of Reliable Electronic Component Supplier in the industry.
Posted on: 2010/7/14 6:52
From Pretoria SA
Hi walterarcher, i apreciate te reply, please, can you explain my knowledge of electronics is..... well...
Posted on: 2010/7/14 6:56
1400 Turbo
From Pretoria SA
I checked the dizzy i have after looking on the sites you all recomended it's defenatly a E15/E16 dizzy that have allready been moddified (lucky i know) just nead a good coil and Bob's your uncle.. Thanks
Posted on: 2010/7/14 7:41
1400 Turbo
