Heating copper lines in Behind Windscreen ?
From Sri Lanka
Hi Guys
What is the machanism that the behind windcreen is getting heated to avoid humid on it,i can see some copper lines on it how can i make it working, as usual i am planing to go my hill country journey at the month end that will be very useful for me as there it is so cold and rainy
thanks
Regards
sumith
Posted on: 2010/7/13 6:54
Re: Heating copper lines in Behind Windscreen ?
From Sri Lanka
Hi Guys
I think this is all about windscreen heater
any one has got any idea how this is done ?
thanks
Regards
sumith
Posted on: 2010/7/13 11:24
From Sydney
Hi it is commonly call a rear demister. It should have electrical connections at either side of the glass. One side is earth and the other side is 12 volts and current runs through the copper lines to heat the glass. Your car should have a no/off switch to control it somewhere on the dash. Hope this helps you out
Posted on: 2010/7/13 13:13
It is an OPTION for Datsun 1200. For details see Defroster, section "rear defroster".
Posted on: 2010/7/14 21:05
From Sri Lanka
Hi DD
Thanks, is the wiring 12v directly going to rear window Heater lines as above DJF280's comments.the picture i am confuses having copper tube to the rear windscreen is it to take wiring there is it ? so what my mind is the heater lines gets voltage from the dash switch ? correct me if i am wrong
thanks
Regards
sumith
Posted on: 2010/7/15 4:33
Did you look at the wiring diagram???
Posted on: 2010/7/15 4:46
From Sri Lanka
Hi DD
Yes Actually, i went through it i understand switch wiring fuse connection etc etc, but i am not clear where it is connecting to rear window
thanks
Regards
sumith
jpg  1.jpg (13.15 KB)
10994_4c3e85cb1de3a.jpg 400X228 px
Posted on: 2010/7/15 4:53
it connects to the copper wires (traces) on the back glass. You should find two of the traces going off to the side, that is where the wiring connects.
Posted on: 2010/7/15 6:37
From Sri Lanka
Hi DD
Noted ,
thanks
Regards
sumith
Posted on: 2010/7/15 7:27
From Sri Lanka
Hi guys
I found the 2 copper line connection in the rear windscreen,when i provide wiring how can i check whether it is working properly, can i feel the heat on the windscreen or can i check the voltage by a multimeter ?
thanks
Regards
sumith
Posted on: 2010/7/16 6:36
