A14 oil problems
From South Africa
We are having a problem with a A14 motor. There is no oil getting to the head and valve train. We have replaced the oil pump already, but still nothing. Some advise PLEASE !!!!!!!!!! We are running a hot A12 head on the engine, but I dont think this is the problem. We did reinstall the origanal A14 head, but still no oil getting up top.
Posted on: 2010/7/25 11:52
___________________________________
2006 Ford Bantam
2004 Ford Ikon
Re: A14 oil problems
From sydney.nsw
you may have the wrong head bolt in the oiler hole, a14 have one bolt longer then the rest, which goes in the center hole, dizy side of the engine. check that first. cheers ernie
Posted on: 2010/7/25 11:57
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
From Brisbane
I recently rebuilt my a15 engine and thought a similar problem was occuring . There is not a large flow of oil to the top end of the engine as i expected but merely enough to lube things up. I ran the engine for a while and i was surprised how long it took to cover the rocker gear. I hope this helps.
Posted on: 2010/7/25 12:04
From South Africa
I have checked the head bolts and the long one is at the oiler hole. Could this oiler hole maybe be blocked and if so how do I clear it, We have been driving the ute for 3 months with that noise, its getting worse not better.
Posted on: 2010/7/25 16:21
2006 Ford Bantam
2004 Ford Ikon
Take a look at this. Both the block and head are different:
Posted on: 2010/7/25 18:40
Also there are two "long" oil bolts, which are the same length:
11057-H2301 BOLT-CYLINDER HEAD LONG, TO OIL GALLERY (TO 6/73)
11057-H5000 BOLT-CYLINDER HEAD LONG, TO OIL GALLERY (FROM 7/73)
Posted on: 2010/7/25 18:47
From South Africa
Ive attached pics of the head, block and Head bolts. everything seems to line up correctly.
jpg  Andre Head.jpg (86.29 KB)
8585_4c4d35ec56eda.jpg 800X600 px
jpg  N 6110 N(001).jpg (101.59 KB)
8585_4c4d36039e4c8.jpg 800X600 px
jpg  N 6110 N(003).jpg (113.89 KB)
8585_4c4d3616061ed.jpg 800X600 px
Posted on: 2010/7/26 8:15
2006 Ford Bantam
2004 Ford Ikon
From Vanderbijlpark, South Africa
i had the same problem a while ago, used 1200 head on 1400 block. ended up that i had to prime the oil pump to get it to build pressure.
Posted on: 2010/7/26 10:16
93' Nissan 1400 a15 60a (daily)
82' Datsun 1400 ute (sold)
73' Datsun 1200gx Coupe (sold)
From South Africa
We found where the noise was coming form. A siezed rocker. We dont want to open the engine, but would this rocker have made a mark or ridge on the cam. ADVISE PLEASE !!!!!!!!!!
Posted on: 2010/7/26 17:49
2006 Ford Bantam
2004 Ford Ikon
Unlikely. The cam and lifter is not lubed by the rocker shaft.
Posted on: 2010/7/26 19:17
