A15 Crank Into Late A12 ???
From Armidale N.S.W
Looked in wiki doesn't say its doable, but wondering if anyone has done or knows if i can put an A15 crank in a late 120y A12 motor my A15 was bought seized but have just discovered how seized it is. 2 pistons are fused to the bores with rust. Motor sat for way to long.
Posted on: 2010/7/26 10:24
73 1200 wagon SOLD
Re: A15 Crank Into Late A12 ???
From Geelong, Vic
100 thou over, she will be fine
Posted on: 2010/7/26 10:26
From Armidale N.S.W
Doubt theres enough meat between cylinders one and 2 (mainly) for that. 40 thou may be enough to clean it up ay
Posted on: 2010/7/26 10:29
73 1200 wagon SOLD
From gold coast QLD australia
I have only fitted an A14 crank into a 1200 block ,makes 1289cc and went quick.the A15 crank is much longer and the pistons would stick out the top too far..
Posted on: 2010/7/26 10:30
GO RACING,GO HARD OR GO HOME!!
SLY OLD FOX..................
I looked at this but will need a10 conrods, custom sump, milled pistons,
clearanced block walls and rod stroke ratio will be 1.48 to low really
but same as the qr25de lots of torque and little up high.
Posted on: 2010/7/26 11:48
From Malaysia
what about putting a a15 crank into a a12a? im thinking of putting a15 crank into my a12a, using a12a stock piston.. is it possible?
Posted on: 2010/7/26 11:51
rod stroke ratio will be 1.48 unfortunately
Posted on: 2010/7/26 12:08
From Malaysia
i dont really know about rod/stroke ratio. i thought the general rule of thumb is "no replacement for displacement".
care to enlighten me about the advantage/disadvantage of low rod/stroke ratio?
thanks in advance.
Posted on: 2010/7/26 12:16
try online theres heaps on it and good reading
other issue is clearance or lack of it, meaning
crank counterweights need to be chopped off at
strategic points and inner block walls clearanced
which weakens it. The A14 is the best and then
boring to 78mm. 77x78 cant go wrong.
Posted on: 2010/7/26 12:45
From Malaysia
ok thanks, i will find it online...
Posted on: 2010/7/26 12:53
