where can i get a clutch push rod to fit 1200 ute?
From Sydney
hey guys i just been looking for a push rod to suite a 1200 ute but can not find none? i got a 13b so i will be using a clutch master of a rx7 ?
Posted on: 2010/7/27 9:46
Re: where can i get a clutch push rod to fit 1200 ute?
From Geelong, Vic
would probably be a little hard trying to find something to fit straight up seems as 1200s use cable clutches
why cant you just make the rod?
Posted on: 2010/7/27 9:47
From Sydney
not sure how to? how did you get your one done?
Posted on: 2010/7/27 9:49
From Geelong, Vic
have a look at my pics, used toyota master mounted ontop of the pedal box behind the dash. rather easy to do and nice and neat
for the actual push rod i just get an adjustable push rod, use the bit that attatches to the pedal and just make a new rod out of a bolt with the same thread. just have to grind the head down to the same kinda shape as what the old push rod had
Posted on: 2010/7/27 10:27
You could get the clutch master cylinder pushrod from an LHD 1200 ute. But it wouldn't fit your RHD pedal... so you might as well fab one up.
Posted on: 2010/7/28 3:59
