Re: 45mm coil over conversion and insert choice
From Sydney
Forgot to mention, be aware that the MK1 Golf inserts are short [extended length] I also fitted some 30mm bump steer spacers to get some angle back into the LCA's. Without [spacers] the LCA sits near horizonal. That would be OK if it was a track setup with stiff springs and minimal suspension travel.
Posted on: 2010/7/29 12:45
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
Subject Poster Date
     45mm coil over conversion and insert choice yz1975 2010/7/29 3:16
       Re: 45mm coil over conversion and insert choice benny 2010/7/29 4:44
         Re: 45mm coil over conversion and insert choice Kiri1 2010/7/29 6:46
           Re: 45mm coil over conversion and insert choice TUF-110 2010/7/29 9:26
             Re: 45mm coil over conversion and insert choice estyre 2010/7/29 9:57
               Re: 45mm coil over conversion and insert choice yz1975 2010/7/29 11:15
                 Re: 45mm coil over conversion and insert choice TUF-110 2010/7/29 11:21
                 Re: 45mm coil over conversion and insert choice yz1975 2010/7/29 11:24
                   Re: 45mm coil over conversion and insert choice benny 2010/7/29 12:13
                     Re: 45mm coil over conversion and insert choice PIGDOG 2010/7/29 12:38
                       Re: 45mm coil over conversion and insert choice benny 2010/7/29 12:45
       Re: 45mm coil over conversion and insert choice yz1975 2010/7/29 13:06
       Re: 45mm coil over conversion and insert choice benny 2010/7/29 23:43
       Re: 45mm coil over conversion and insert choice nick_m 2010/7/30 4:34
