A Series Pushrods
From Tas
What have you guys done about pushrods in your modified A12,A14,A15's.
I'm stripped down and ready for the rebuild of my A15 and I'm just planning everything out to make sure its done properly. I just wasn't sure about the pushrods - have you guys stuck with standard ones, are there stronger/lighter ones available - custom perhaps. Same with the lifters and rocker gear as well.
Just thought I'd ask. Thanx in Advance
Posted on: 2003/12/11 23:50
Re: A Series Pushrods
From Sydney, Australia
I think some of the hardcore racers use "hollowed titanium pushrods" as every moving part and it's associated momentum, all contribute to power loss. I think Nismo can supply them.
But generally I think you'll find the old pushrods are retained in 95% of street engines.
I'm sure some of our racing buddies will give you the good oil.
Chris.
Posted on: 2003/12/12 1:19
We run standard pushrods to 8,500 rpm and have not had the slightest trouble.
Go for it!
StewMcK
Posted on: 2003/12/12 3:07
From GOLD COAST AUZ
PRAY when you get to 9300 rpm`s and over, that is when I have them take a Z`ed shape and hard to take out of the head thay lock in.Had no prob`s under that rpm.
Posted on: 2003/12/14 10:28
rather be a old fart than a young d##khead
From Perth
I use Crow Cams cromolly pushrods with balls on both ends.
Though I use YT roller rockers also so I needd diffrent rods as the orig are cup and ball.
Posted on: 2003/12/14 14:40
