95 barina cold start/ acceleration issue
From illawarra, nsw australia
Gday
my sister was virtualy given a 1995 sb barina innearly perfect condition,
BUT it has a small issue with cold starts
it starts good after we cleaned the rotor cap and button (elec dizzy)
but idles a bit rough and will only just take off with very light acceleration
any more then 1/8 depression of the pedal will cause it to shutter reely bad and nearly stall
its an auto with a carbouretor
and when it warms up it runs faultlessly and is quite nippy
this is a problem only because the car is only driven short distances less then 10-15 minute drives
is it plausible that the carb gasket is leaking causing there to be loss of vaccum and a bad mixture, when the manifold warms it swells and closes the gap?
Or does this point towards a choke issue?
(auto choke)
as always help is greatly appreciated
thanks
jason
Posted on: 2010/8/6 0:29
Re: 95 barina cold start/ acceleration issue
From hastings,vic
should hav throttle body injection,c12nz or c14nz engine
early camira type injection
check coolent temp sender
check rest of ignition ,needs more spark when cold
tommo
Posted on: 2010/8/6 0:41
taking up room at home
hzj75 cruzer tray(for sale)
and allways changing
most likely cause, spark plug gap is worn too big. Remove and inspect is easy.
Posted on: 2010/8/6 2:34
hey thanks for the heads up guys
Will look into that tomoro.
Was at the wreckers with a mate and we looked at a 96 barina which had an opel rocker cover and was injected. But sisters is definatly carb.
Anyway thanks guys.
Posted on: 2010/8/7 10:52
datsunless. for now
