Hey Gents!
...as will any carbs that are used.
Yes indeed. But no it isn't as exciting as super long runners, quite the opposite actually, super short.
I got a matching air housing for my new keihin carbs (Like, brand new carbs!) and it all goes together so well (+ cheap replacement filters) that I'm pretty damn keen to use it as a complete induction unit. It also has a perfect PCV provision right where the A-Series need it.
Yes I know the approach angles are hard to achieve but I don't mind an extra bend in the flow into the head if it has to come to that. I could even put up with a big port round-port head (without the gradient of the oval-port approach angle) if it is easier to fabricate.
I have approximately 75mm clearance maybe a little more and I need about 150mm. I have a design for a shorter rocker cover but I just thought I'd ask before I did anything.
What would happen if I reduced the size of the sump/oil capacity? Perhaps I could make a flying (winged ) sump to compensate for the dimension reduction but maintain capacity?
