Air Filter Options
From Brisbane
I put on the Air Filter housing, but it hits the bonnet ...
What are my options?
Thinner air filter? Where can i get one? Why is my carby so high?
Diff Carby?
Posted on: 2010/8/5 12:03
Re: Air Filter Options
From Brisbane
Sorry ... Forgot this ...
Hi Hamza,
Not sure where that one came from but it may be a little too big? Maybe try and source a stock A12 one (pretty easy to find) or 1000 one (harder to find)?
I think you should just go with a pair of sidedraft carbs no clearance issues there!
Posted on: 2010/8/5 21:54
From Brisbane
Sidedraft was what i had in mind ...
Any suggestions? (Remember im a total noob, so something easy to fit and tune)
Hamza
Posted on: 2010/8/6 0:02
Stock Datsun 1200 air clean housing will hit the bonnet in a Datsun 1000, isn't that right? engine block is a little bit taller.
Posted on: 2010/8/6 2:36
From Coondle, WA Australia
a stock 1200 frypan filter will fit under the bonnet in a 1k. At least all my ones did.
Its starts to become squishy when you use the taller a14/15 block.
A10/a12 block with standard frypan filter should be fine.
Posted on: 2010/8/6 2:38
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
From Vanderbijlpark, South Africa
i used a golf 1 air filter bracket and drilled a hole in the centre with a pipe and cone filter.
jpg  IMAG0302.jpg (93.97 KB)
12028_4c5bc2daa11d1.jpg 800X600 px
Posted on: 2010/8/6 9:07
93' Nissan 1400 a15 60a (daily)
82' Datsun 1400 ute (sold)
73' Datsun 1200gx Coupe (sold)
That's funny, I had no problems with the factory 1200 induction on my 1200 engine in a B10.
[click on image for full size picture.]
OK enough with the funnies, here's the deal.
The A10 was the shortest [vertical measure] A series engine of all & the B10 car had the lowest bonnet line.
ANY stock non-A10 single carb engine will have clearance issues between the stock air filter assembly & the bonnet. This is because every other A series engine is taller than the A10 & the original clearance was much tighter than you might have imagined.
Now that you know the cause of the problem, you can look at practical options. Dinky little 'sports' air filters will work but are not really a proper solution, however the conical filter on the end of a tube looks to be a good idea to me
Posted on: 2010/8/6 13:54
Love your Datsun.
Treat it well.
I have a spare A10 one you can borrow until you find another.
Chris
Posted on: 2010/8/7 3:53
The stock A10 air filter clamps around the inlet neck of the carb.
This was changed for the 1200 & all subsequent A series engines to a central mounted stud, so the A10 air filter housing will work only with the original A10 carb.
The problem is not with the height of the air filter housing, but instead with the height of the engine itself so even if a stock A10 carb & air filter was bolted to the 1200 inlet manifold, it would still rub under the bonnet.
Posted on: 2010/8/7 12:37
Love your Datsun.
Treat it well.
