« 1 ... 3 4 5 (6) 7 8 »
Re: Datsun GX Coupe from South Africa
From Centurion
Well the engine is out again and so is the front suspension. Time to give the front suspension a make over. And also to make the final engine mounts.
Also busy with the steering rack.
Posted on: 2010/8/7 18:26
Datsun GX Coupe
4AGE 20v Silver Top
That is a nice looking engine
Posted on: 2010/8/8 1:09
From Centurion
Thanx. that was my first thought as well when i saw one. So it quickly got me thinking. And so it landed up in my garage. Ended up with more mods to do but i'm sure it will be all worth it at the end of the day.
160hp stock standard, sure it will give me some serious fun.............
Posted on: 2010/8/8 15:15
Datsun GX Coupe
4AGE 20v Silver Top
Re: 20 valve Datsun GX Coupe from South Africa
From Centurion
The templates is complete for the plates on the engine for the mountings. Now it is to get the pipes bend and welded. Hope to get this finished before the weekend. Then i can get the front suspension back in the body. And then the engine in its place.
Still so much work to do........
Below is a sample of the engine mount i want to get
jpg  IMG00014-20100616-1245.jpg (170.06 KB)
13457_4c5ebd7856c4c.jpg 691X922 px
Posted on: 2010/8/8 15:22
Datsun GX Coupe
4AGE 20v Silver Top
From Cape Town ZA
You don't need to modify the cross member like in the picture above, also it's much easier and neater to make the mountings from plate. Have a look at all the pics under my profile, I did the same conversion, just with a 16V, but the mounting and positioning of the motor will be exactly the same, as will most of the water pipes and stuff...
You don't need to modify the tunnel to fit the 21R gearbox, apart from a bit of panel beating with a ball peen hammer and moving the lever hole backwards about 100mm.
Posted on: 2010/8/8 21:26
1200 GX Sedan
New(being installed)
4AGE 20V NA
Old
4AGZE 16V turbo
196.5KW/283NM
800m - 200km/h
400m - 12.3s
From Centurion
Must say that they look a lot simpler. Will see what i'm going to do.
At least the x-member and front suspension is back in the GX. Just need to re-grease the bearings and put them back. Then i can do all the steering bits and peaces.
Need to get the radiator to see how far the engine needs to shift back for clearance. Then the engine mounts can be finalised. Coming along slowly.
Posted on: 2010/8/9 17:27
Datsun GX Coupe
4AGE 20v Silver Top
From Centurion
progress is very slow on my side , just not getting the time to do much work on the GX.
Wondering should i stay with the round headlights or should i go for the square ones ?
Then i also need help with the window winders , i have 2 different ones. Which one is for the GX and which one for the UTE ???
Below is the two winders i have
jpg  IMG00010-20100924-1405.jpg (127.96 KB)
13457_4ca0bec8e7f9e.jpg 1344X1008 px
jpg  winder a.jpg (152.21 KB)
13457_4ca0bede674a1.jpg 1004X753 px
jpg  winder b.jpg (193.31 KB)
13457_4ca0bef5ad09b.jpg 1057X793 px
Posted on: 2010/9/27 16:36
Edited by hattinid on 2010/9/27 16:57:49
Datsun GX Coupe
4AGE 20v Silver Top
From Cape Town, South Africa
Winder B looks like the ones on my 1200.
Posted on: 2010/9/28 10:49
Project Build: http://datsun1200.com/modules/newbb/viewtopic.php?topic_id=45104&forum=9
Don't find a problem, find a solution!!!!
www.race-tech.co.za
From Centurion
Searched the net like mad and found this on a website for new Datsun spares
DATSUN 1200 WINDOW REGULATORS
PART: 12IN04R (for right)
PART: 12IN04L (for left)
Correct For Sedans, Coupes and Wagons (B110) 1970, 1971, 1972, 1973
jpg  1200IN0004.jpg (25.28 KB)
13457_4cab63fc66565.jpg 217X163 px
Posted on: 2010/10/5 18:44
Datsun GX Coupe
4AGE 20v Silver Top
From Centurion
now i'm completely lost
Posted on: 2010/10/5 18:46
Datsun GX Coupe
4AGE 20v Silver Top
