CA18det turbo water line block fitting (size and thread pitch)
From Brisbane
I want to replace the fitting on the CA18DET block with an adapter and run an AN fitting with braided hose to the turbo, along with the other hoses. Does anyone know the size and thread pitch for the block fitting for the turbo water line? It is the fitting circle in the pic below.
Edit: i found the info on NICO http://forums.nicoclub.com/how-to-make-turbo-lines-t254366.html if anyone else was after it.
jpg  ca18det turbo.JPG (99.30 KB)
7166_4c5d03f2e05ad.jpg 1120X628 px
Posted on: 2010/8/7 8:09
Edited by ___1200ute on 2010/8/7 9:19:07
Re: CA18det turbo water line block fitting (size and thread pitch)
From Geelong, Vic
why wouldnt you just keep that fitting and get a braided line with banjo fittings on the end of it?
Posted on: 2010/8/7 9:38
From Brisbane
No real reason, just want to use AN fittings.
Posted on: 2010/8/7 9:53
i bought a kit off ebay for like 90 bucks that will bolt up to a t25/t28 on a ca that uses an fittings and banjo bolts. have a look on ebay.
i need the bits that bolt into the block if you have any spare
Posted on: 2010/8/8 1:29
Car free
