wheels to fit 1200 sedan with stanza front brake conversion!
From Sydney
hey guys im new to this site ive owned my 1200 for a while and have done quite a few things to it.. my question is about wheels size and tyre size..
im trying to get it engineered and i have found a set of 14"r31 skyline steel wheels and have fitted 185/65 r14 tyres on it and it they scrub the front guards...
i have stanza front brakes, control arms, and struts in the car.
just wanna know what other steel rims will fit in 14" without scrubing the guards.
must be 14" as 13's dont fit over my rear brakes any help would be appreciated thanks in advance!
Posted on: 2010/8/23 14:07
Re: wheels to fit 1200 sedan with stanza front brake conversion!
From Mandurah, Western Australia
Ive got the same setup and needed to trim the front guard at the front edge, when I set the car to its current ride height.
I know you want 14 but 13 inch Mitsubish colt rims with 155 or 175 tyres work well.
Posted on: 2010/8/23 14:38
From Sydney
ohk fair enough my trimming the front guard what do u mean exactly? i'd get 13's but they wont fit over my rear brakes the only reason im doin all this mucking around with wheels is to get the rest of my car engineered
Posted on: 2010/8/23 22:23
From Armidale N.S.W
Have you tried 14 inch 200b rims ? Also have you tried 13 or 14 inch mag wheels (Alloy wheels)? They seem to fit better than steel rims depending on offset of course.
Posted on: 2010/8/23 22:29
73 1200 wagon CA project
80 1200 ute Full resto, Ca18det Project.
76 1200 Ute A14, Daily, Soon L18 5 speed.
From sydney australia
Try 14 inch wheels from a Mitsubishi Sigma or Scorpion. I used these on a 1000 race car as trailer wheels with some 175/60x14's. Also check C22 Nomad steel wheels. You could also try some Bluebird wheels, some of the site members have used on their cars. I'd recommend the 175/60's as a tyre size. The part of the guard that needs trimming is the lower front corner of the wheel opening. You can usually get enough clearance if you fold the lip over & pull that corner out slightly, or put another fold in that part of the guard, usually 5 mm or so will be enough.
Posted on: 2010/8/24 10:31
From Sydney
ohk thanks heaps guys ill try bending the guards out a bit and if all else fails there will be a set of r31 skyline 14" steel whels with good tyres for sale and ill fid a set of sigma wheels..
Posted on: 2010/8/24 13:58
From Boredomville Melbourne
so the tile of the thread is wrong, you need rims to fit your rear brakes, cause 13's clear stanza brakes.
Posted on: 2010/8/24 22:59
Was B110 Sedan: L series and 5 speeds, the way they should have been
Now A10 Stanza: L series and 5 speeds...
From Brisbane
hi mate
you need to make sure you have the right tyres, not just he right rims. a 185/65/14 is probably quite tall compared to the standard tyre?
Posted on: 2010/8/25 8:24
