wheel size
From BlueMountains NSW
at moment i have 12inch steels on 75 120y.
without changing anything what size mag can i go up to.
I thinking of going up to 13inch jelly beans mag?
Posted on: 2010/8/24 2:04
I DON'T LIVE IN THE PAST....I JUST TAKE DAY TRIPS
Re: wheel size
From Brisbane
i didnt change anything when i went to 13's
Posted on: 2010/8/24 2:47
Re: wheel size
you can go to 17" without changing any thing except the wheel and tire. The tire needs to be a smaller diameter one, and the wheel needs to be the right offset.
Posted on: 2010/8/24 3:10
Re: wheel size
From Ringwood, Melbourne, AUS
It's all about offset and rolling diameter..
Get them right and nearly any diameter can fit..
Posted on: 2010/8/24 3:33
Deano
Re: wheel size
I like to match the stock tyre diameter. This boils down to working out the best tyre profile for your chosen rim diameter and tyre width.
For example, say you would like to run 13" rims and a 185 wide tyre. You want to work out the profile to give you close to stock tyre diameter.
Tyre diameter is
rim diameter + twice the tyre sidewall height
Now for the stock setup of 12" rims and 155/80 tyres this is
(12 * 25.4) + (2 * 155 * 0.8) = 552.8 mm
For a 13" rim and 185/60 tyres we get
(13 * 25.4) + (2 * 185 * 0.6) = 552.2 mm
which is pretty close to stock diameter.
Posted on: 2010/8/24 6:16
Re: wheel size
From Brisbane
I've just gone to 175/60/14s using steel wheels from an 80's Toyota Corona. I'll have them back tonight and will post a pic as long as they fit :)
Posted on: 2010/8/24 6:34
Re: wheel size
From Geelong, Vic
tire size calculator
will make matching tire sizes nice and easy, 155-80 12s arent actually the stock size i dont think...pretty sure the cross plys were taller
Posted on: 2010/8/24 7:47
Re: wheel size
thanks guys now I can go for it.
cheers Bazz
Posted on: 2010/8/24 13:09
Re: wheel size
Offset calculator here also good for checking clearances etc..
http://marksink.com/tire_wheel_offset/offset.html
Posted on: 2010/8/24 13:19
Deano
Re: wheel size
From Brisbane
I've just gone to 175/65/14s using steel wheels from an 80's Toyota Corona. I'll have them back tonight and will post a pic as long as they fit :)
Hi mate, just an update on this. I used steel wheels from an ST141/RT142 Toyota Corona. Most models of the Toyota Corona with 14" wheels will be the same fitment so should not pose an issue.
Your local wrecking yard will sell you a full set of these for under fifty bucks.
Not a very good picture, but if gives you an idea how they look. I'll get some better pictures when I can get at the car in daylight!
Posted on: 2010/8/24 14:25
