(1) 2 3 4 ... 10 »
E15/16 vs A15
From Coondle, WA Australia
Folks
Been doing some thinking, and just to get some opinions, whats people take om the E15 vs A15 engine
E series - gets EFI, OHC, Turbo as standard.115hp at flywheel standard
A series - indestructable.69hp at the flywheel standard.
My project plans was for an EFI, turbo a15 into the 1000 4 door and by the time you get the manifolds and efi gear together, a e-series starts to look appealing, cost wise that is.
Im keen to keep the A15 as its in the shed, ready to go, all new a rebuilt.
Just chasing opinions is all folks.
The
Posted on: 2010/9/4 5:29
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
Re: E15/16 vs A15
You can get 115HP from an A15 turbo not too difficult. Just use an intercooler. The E15ET did not use one and was limited to a maybe 5 pounds of boost.
Posted on: 2010/9/4 5:46
Re: E15/16 vs A15
From Adelaide
Also interested in opinions on this since they still seem to be sitting in wrecking yards. The one in my Nana's Prarie is still kicking on strong. From what I've read the conversion is similar, especially if going for coil on plug!
Posted on: 2010/9/4 5:47
Re: E15/16 vs A15
Good motor the E-Series.
The only thing stopping me from doing the same thing is the fact that I love the A-Series. I can;t imagine seeing any other kind of rocker cover under the bonnet (unless it has Tomei 1300 written on it!).
There was a very powerful E-Series engine for sale from a member here some years ago and with similar work carried out (in what you'd do to an A-Series) it produced some very impressive (I should say surprising) figures......and it sold for $600.00 which was about a 6th of what it was worth.
Do it Reuben, the only hurdle is the dizzie but I'm sure you can adapt a different ignition system (crank ignition?). All the other little nigglings are fairly easy to address.
Good luck if you take it on.
Posted on: 2010/9/4 6:06
Re: E15/16 vs A15
The only problem is it is so ugly. Scalloped valve cover...
E16I from Pulsar NX
Posted on: 2010/9/4 6:48
Re: E15/16 vs A15
I know what you mean DD
I doubt that there is anything that has the clean lines the a-series. And I have bucket loads of parts for em.
I also have a sense of originalyity for the a-series for the thou. I know it was an a10, but the a15 is the same family.
But the e-series is just so attractive for the ease of install.
I will still have to make custom mounts for the a15 in install.
the e-series bolts up to the gearbox easy enough.
it ceratinly is worth some more research into performance. I have a friend that rallyed an exa for a while, before he went to a honda prelude. They ditched the exa simply cause it couldnt produce enough speed on the gravel in NA form. He reckons in the turbo form, it would have, but thats another class etc.
He has a heap of parts lying about at home, so im gonna raid his pile for some trails i think.
Posted on: 2010/9/4 7:15
Re: E15/16 vs A15
The Nissan E engine was a major redesign of the Nissan A engine, specifically to fit Front-Wheel Drive vehicles. The first variation, E15, debuted in the 1982 Pulsar (N10 "Datsun 310"), replacing the A15. it has an identical bore & stroke.
From Nissan Product Bulletin Vol 75.
The E-engine is an extensively improved version of the A-engine...
The E-engine provides higher power and greater torque than the A-engine. Its dynamic performance, as in standing start, passing acceleration, upgrade driving, etc. has been increased by 5 to 10%. A summary of the major improvements is as follows:
1. The E-engine is approximately 10kg (22 lb) lighter than the A-engine
2. An O.H.C., cross-flow engine design provides high torque as well as responsiveness to acceleration.
3. The cylinder pitch is identical to that of the A-engine, which has already been proven to be both duarable and reliable
4. The overall length has been shortened by 48mm (1.89 in) to accomodate the in-line transaxle design.
Posted on: 2010/9/4 7:30
Re: E15/16 vs A15
That makes it even more intresting DD.
10kg lighter, crossflow, turbo, efi, 115hp standard.
am i missing something?
Posted on: 2010/9/4 8:19
Re: E15/16 vs A15
The E15ET weighs more than 10kg lighter. That was the original the E15S (single carb).
E15ET has a better looking valve cover too:
Posted on: 2010/9/4 8:27
Re: E15/16 vs A15
From Rosewood, QLD
has anyone done this before? what problems are there with engine mounts and getting a RWD 5 speed to fit?... i think i have found the engine for my new daily.
Posted on: 2010/9/4 8:40
1971 B110 sedan project.
2012 Nissan Micra daily.
(1) 2 3 4 ... 10 »
