L20b to Stumpy 5 speed, What clutch?
From Mildura, VIC
Guys, L20b to stumpy 5 speed conversion, after a LONG time, I've got back into the conversion.
What clutch / flywheels are guys using - R30? - 200b?
I don't have a clutch or a flywheel at present and I'm after something light, and cheap!
Posted on: 2010/9/12 5:05
Re: L20b to Stumpy 5 speed, What clutch?
Use the stock L20B clutch. 200mm with the 63-series spline.
Posted on: 2010/9/12 5:23
From Mildura, VIC
Being I've got to get a cluch & flywheel, can anyone recommend something that may be from another model that is lighter, greater clamping pressure ect.
Posted on: 2010/9/12 5:59
ive got a hd clutch form a workrd L16 to stumpy fs if your interested
Posted on: 2010/9/12 7:41
Car free
From Mildura, VIC
What flywheel was it using? - L16 is 5 hole, are the bolt paterns the same for the clutches to the flywheels?
Posted on: 2010/9/12 9:59
From Geelong, Vic
R30 stumpy or sss stanza stumpy?
if its an R30 get a 6 cylinder flywheel, dont know which one would be lightest but they take a bigger clutch, and doesnt cost all that much to have a flywheel lightened. then a 280zx turbo clutch has teh heaviest clamping force
if sss stanza you have to use L20b flywheel and clutch as the 6 cylinder clutches dont fit in
most 4 cylider clutches have the same bolt spacing, but are only 200mm, think 1600 ones are smaller again, 720 and z18et are the same size as 6 cylinder ones
6 cylinder clutches are 225mm
Posted on: 2010/9/12 11:08
From Mildura, VIC
The box is R30 Stumpy. Thanks Pigdog...
Posted on: 2010/9/12 20:30
From Mildura, VIC
Went with the r30 clutch & fly, weight difference between the 4 cyl & r30 flywheels out of the factory is unreal!
Posted on: 2010/9/13 8:50
From RAdelaide
Damn thought i was going to be able drive to your house to see what progress you had made with the clutch.......in the 120y! HAHA ( i dont believe in LOL )
Posted on: 2010/9/13 11:57
"My mind is a raging torrent, flooded with rivulets of thought, cascading into a waterfall of creative alternatives." - Hedley Lamarr, Blazing Saddles
From Mildura, VIC
It isn't finished yet...
You probably will be able too.
Posted on: 2010/9/13 20:21
