100a suggestions ?
I have a 1979 datsun 4 door 100a cherry, does anybody have any imformation about what engines, engine mods, gearbox etc will fit this, yes it front
wheel drive :(
Posted on: 2001/6/5 6:58
Re: 100a suggestions ?
From Finland
It
Posted on: 2001/6/5 7:08
From Invercargill, New Zealand
Try the E16 and 5 speed from the Sentra/Sunny or if your budget allows it the EXA Pulsar Turbo motor. She'd be a head turning, bag scorching stealth fighter with the latter choice. FWD
is OK - I admire anyone who is devoted to the F100A/Cherry - that's way cool and edgy.
Posted on: 2001/6/5 7:32
From UK
I fitted an A14 from a B310 into my F10 wagon. See it at www.ratdat.com. Look in the "what's new" section... it's listed there or go to the Technical section. I need to add a
few things though like the top A10 stabalisers aren't strong enough for an A14 and neither is the A10 clutch (you need a F10 120A or N10 Cherry clutch) It also has 15 inch
Saab Turbo wheels now to improve the gearing. I will eventually fit a 5 speed from an N10 which also have a higher diff ratio. The next stage will be a brake upgrade.
Eddie
www.ratdat.com
Posted on: 2001/6/5 11:52
From Finland
Some pictures of A14 powered 100As can be found here:
http://members.surfeu.fi/datsun_1200/muut100A.htm
These are earlier E10 models but it
Posted on: 2001/6/6 1:31
Will the A15 out of a 1983 sunny bolt straight in? and will the N10 5speed gearbox from a similar year pulsar bolt straight in
with the A15?
Posted on: 2001/6/7 6:28
From Finland
If you take A15 out of Sunny, you must do some mods before installing it into 100A. You have to change the oil sump, inlet and exhaust manifolds and thermostat cover. If you
Posted on: 2001/6/7 7:00
you say change the oil sump... do you mean change the a15 oil sump or the
100a oil sump?
Posted on: 2001/6/7 7:29
100a suggestions ?
From Finland
You have to use the original 100A oil sump.
Posted on: 2001/6/8 12:19
