« 1 (2)
Re: Rear discs dragging
i have no idea what this is. The rear brake line goes to it, then back to the other side and on to the diff.
Posted on: 2010/9/21 4:11
Ok, Nissan part type 46400 is:
46: Master cylinder, pedal &, piping group
400: Load Sensing Valve Assembly
i was wrong again...
Posted on: 2010/9/21 4:19
From Okinawa, Japan
So I shouldn't remove that, I'm assuming? I may bypass it tonight anyway, just to see. There's not enough wheel travel on my truck for that thing to work in the first place.
Posted on: 2010/9/21 7:05
From NZ
It's check valve to maintain brake shoe position. With discs now fitted it should be removed and bypassed.
Posted on: 2010/9/21 11:37
1200 Coupe Racecar, mid-mount A13, C/R 60L g'box.
Previous "Datsuns": B310 sedan worked A13. B310 coupe A14/dogleg 5-spd. 260C sedan, L26, 3-spd man col chng, 6-seater great tow car!. VL wagon, RB30, 5-spd. Nissan Bluebird SSS U13, SR20, 5-spd.[i...
That's in the master cylinder.
The load sensing valve normally has a lever on it, to adust brake proportioning.
Posted on: 2010/9/21 17:08
From Okinawa, Japan
So I removed the valve, and no change, so that's not it. I probably goofed rebuilding them somehow... I'll report back when I figure it out.
Posted on: 2010/9/22 6:26
hey josh does that valve move somehow?
There is an angled channel in the sheet metal right there, I wonder if that moves the valve somehow when there is heavy load in the bed...?
Posted on: 2010/9/22 6:32
From Okinawa, Japan
No, it was solid mounted. Looks like there's room inside it for something to slide back and forth. I got some calipers from a friend and swapped them at lunch today. I must have buggered something on the rebuild because they work great. Now I just need to work out the e-brake.
Posted on: 2010/9/22 10:05
« 1 (2)
