wtb stock a12 carburettor +mani. or a12gx carburettor+mani.
From campbelltown (sydney) australia
anyone got a a12 carby and mani or 12 gx carby and mani, my webber is crap and i just want my engine to run properly.
Posted on: 2004/1/4 7:10
Re: wtb stock a12 carburettor +mani. or a12gx carburettor+mani.
From Brisbane Australia
Why don't you get your carby rebuilt by a specialist, I had my std 1200 carby done now starts first pop and idles like a dream and also no choke at all.
I have a carby and will gladly swap it for your webber..cheers Ade
Posted on: 2004/1/4 8:08
hahaha nah mate no swappin, but ill buy urs off u, how much u want for it?
the webber may be no good on my engine but its worth much more than the stock 1200 one. ive had the webber set up by a good carby guy and its just plain old over carburettored.
Posted on: 2004/1/4 9:10
From Melbourne, Australia
what weber is it???
down or side???
i pressumed u were talking bout a 32/36 or something, the other guy prob did aswell
if anyone wants a 32/36 i have a few at $25each, condition unknown, i pulled off escorts and cortinas at wreckers
Posted on: 2004/1/4 9:20
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
yeah its down draught 32/36, its way over kill for an a12 so im throwing on a a12 just to have better fuel economy and better response etc till i get a good performance engine.
Posted on: 2004/1/4 10:41
i always say to get a mechanic to setup the carby for that reason, so many people think theres a prob with the carby and wheter it suits the motor
when it does suit the motor, is an awesome upgrade and will make your car heaps quicker if u just fork out the dosh to get it setup properly by a pro
i never play with the carbs cause i know it is a place that you can really screw up your car if it isnt done right
anyway, thats just my opion, your crazy to take it off its a great upgrade if you can afford to get the carb setup right which may require a rebuild but shouldnt cost more than $220 including that and jetting
i hear a common prob with em is actually the base plate of the carb warping and allowing leaks between it and the manifold
Posted on: 2004/1/4 11:10
1200 Coupe Rallycar
32/36 weber is not "way overkill" for a 1200. My totally stock engine (except for 1.75 inch exhaust) ran very well with a 32/36. The only problem I had was a small flat spot just off-idle. But it was very driveable. My fuel economy probably did drop about 25% percent -- but mostly because I drove the engine much harder!
- Advantage: more power, engine revved 1000 rpm higher with usable power
- Disadavantage: flat spot off-idle. Using the stock Nissan throttle-bore-extender tube in the manifold helped, as did proper jetting.
That being said, in the end I did go back to the Hitachi ... which is a good carb in its own right (perfect fuel economy, excellent throttle response).
Posted on: 2004/1/4 17:19
what is it worth to you I am open to offers
Ade
Posted on: 2004/1/5 8:48
From Christchurch NZ
hEY Ddgonzal , what size jets were you running?
Posted on: 2004/1/10 21:14
Forced Induction!
is too much ever enough?
Posted on: 2004/1/11 6:02
