Reversing Lights in Dogleg 5 Speed
From Perth, Australia
I've recently replaced the auto trans in my 120Y with a 5 speed manual (Dogleg pattern).
The reversing lights are on constantly and I can't figure out why.
Is there anyone out there who has encountered this before ?
There is a second plug in the side of the box with 2 spade ternimals but I've been told that's something to do with the anti pollution in 5th gear.
I'll take all the help I can on this guys. Thanks in Advance !
Posted on: 2004/1/5 8:44
Re: Reversing Lights in Dogleg 5 Speed
From GOLD COAST AUZ
Reverse light swith is the back one, frount one is high speed lean out
Posted on: 2004/1/5 8:49
rather be a old fart than a young d##khead
From Christchurch NZ
ANOTHER TRICK IS TO RUN THE WIRES THROUGH THE FIREWALL TO A SWITCH. YOU CAN SCARE OFF TAILGATERS BY FLASHING YOUR BACK UP LIGHT AT THEM
Posted on: 2004/1/5 9:43
Forced Induction!
From Brisbane Australia
I had the exact same problem,I tried three different switches, same answer lights stayed on.
I did the quick fix and ran to a switch under the dash-not the best way but it managed a RWC.
Ade
Posted on: 2004/1/7 11:13
From Melbourne, Australia
ive got same prob with 4 speed box
solution: no reverse lights
Posted on: 2004/1/7 11:15
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
I've just resolved what the problem was guys.... the swith itself was the wrong one to use, the shaft was the wrong length. I replaced it with the correct switch and everything is cool. If you can't get the right one, perhaps using a spacer or something might help ?
Posted on: 2004/1/7 23:37
What switch did you use ??
thanks Ade
Posted on: 2004/1/9 10:48
