(1) 2 3 4 »
Best Tyre Size
From Malaysia
Suddenly it came across my mind...
What is the best front tyre size for a 700kg B110??
As i know, contact surface n weight will effect the grip of a tyre...
Any idea?
Btw wats the weight distribution of B110??
Thanks
Posted on: 2010/10/20 14:24
Edited by ronald_loulan on 2010/10/21 1:49:55
Re: Best Tyre Size
From Christchurch
I reckon a 175 is a good width for a 1200 body and weight wise. But if you have a decent amount of horse power you'll more than likely need a bit bigger tyre to get the power down. It really depends on wheels size and what motor your running
Posted on: 2010/10/20 22:05
Re: Best Tyre Size
From Malaysia
Opps,i forget to mention...
For front tyre...
If its a 150hp motor means i should use bigger wheel at the rear but how bout the front?
The car would understeer using 175,rite?
Posted on: 2010/10/21 1:53
B110 1972 Modded A15
Re: Best Tyre Size
From south coast nsw
i have 165 50 on the front nothing to special, no understeer.165 70 may be different, but is not a race car.if your front is setup right 175 would have good grip with a decent tyre.locked diff might make it understeer into a corner?14" have the best tyre width options in my book.
Posted on: 2010/10/21 2:12
Re: Best Tyre Size
From Malaysia
Yea,im thinking of something like 185/60r14 for best grip/performance...
Locked diff always make my car under alot...
I used to hv corolla Ke70 wif lock diff with same size tyre but wont under steer like my B110...
Isit bcoz of the weight of the car???
Posted on: 2010/10/21 2:28
Re: Best Tyre Size
Better for what???
* Wider tire is better grip
* Narrower tire is better economy
The HP or weight doesn't matter. And we haven't even talked about tire height.
Posted on: 2010/10/21 2:32
Re: Best Tyre Size
From Malaysia
I mean better in terms of cornering/street racing....
But isnt wide tyre without enough weight on it wont perform better???
Posted on: 2010/10/21 2:54
Re: Best Tyre Size
Nope, wider the better in normal circumstances. Not counting rain or loose surface.
Posted on: 2010/10/21 3:04
Re: Best Tyre Size
From Malaysia
Ohh...
60:40??
Posted on: 2010/10/21 3:20
Re: Best Tyre Size
nah the B110 is much better than that it is 54/46. Mostly it is FWD cars are that nose-heavy (60/40).
Posted on: 2010/10/21 3:29
(1) 2 3 4 »
