« 1 2 3 4 (5)
Re: Supercharger Dilemma sc14 vs sc12 vs amr500
From Christchurch NZ
I may have had the webber jetted a bit rich. (to protect the engine)
Although on longer journey, (With prolonged cruising) it's not really much worse than a standard A15.
But getting on the go pedal it bores thorugh the juice. It does seem less thirsty with the holley though. But in truth I don't drive it often. Probably about 50/50 street and strip.
Posted on: 2010/6/10 9:33
Forced Induction!
Just looking at these exhaust on this engine made in the 1920s also twin ohc
and beautiful compact head.
http://upload.wikimedia.org/wikipedia ... 38/Napier_Lion_cambox.jpg
Posted on: 2010/8/14 12:04
From Malaysia
Can i juz use the v-belt(cogged belt) frm std A15 a/c pulley and change SC pulley with a/c pump pulley???
Will it grip or it will squeak??
Im thinking to run 5psi with cog belt....
Posted on: 2010/10/26 14:53
B110 1972 Modded A15
Im not familiar with the cogged belt just the v belt on the A series
But a v belt wont be enough if its just a single you need a twin v belt.
A cogged belt (like that on cam belts) can be used but youll also
need a tensioner to save the supercharger in case of a backfire.
Posted on: 2010/10/26 23:47
« 1 2 3 4 (5)
